Plaster Sand - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 03:53 PM   #1
Rewards Points: 1,062
Question
plaster sand
i need to do some plaster over brick repair.
i was told to use hydraulic lime and not cement and to use regular (coarser) sand for the first two coats and fine white or silver sand for the final coat.
when i went to a local masonry supply dealer, all they had was CONCRETE SAND (coarse) and MASONRY SAND (finer). but they didn't have any white or silver sand.
it is hard to take pictures or in some other way convey the texture of sand over the internet but i am wondering if anyone could wager a bet whether these two kinds that i got would correspond to the coarser and finer sands that i need. or should i altogether get rid of the concrete sand and use masonry sand for the initial coats and look for white sand elsewhere. the masonry sand that i got is pretty fine compared to the concrete one but it is still kind of quartzy, i.e. has granules and is not powdery.
thanks
Tags
plaster , sand
can sand be added to perlite plaster like Structo-Lite diy888 Drywall & Plaster 3 12-14-2011 07:45 PM
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 09:28 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
