Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-09-2013, 02:09 PM   #1
Plaster repair materials
Hey folks...
I've read through some of the threads related to plaster repair on here the last few days. I hate to rehash an already-addressed subject, but...
I have a lot of small areas to repair. The house was built in 1914, all the walls are original plaster. The ceilings are plaster as well, though former owners furred them out and installed ceiling tiles of some sort (late 80's).
Due to various renovations, doorknobs, house settling, etc, there are some cracks and areas I've patched with Sheetrock. I've gotten them as close to level with the plaster as possible, trying to leave a little depth for whatever plaster type compound I'll use...and that's the question.
Do I use joint compound? Repair compound? Is actual plaster still available? It doesn't have to be perfect but decent enough to paint. I've done small fixes with joint compound in the past...
I'd love to rip it all down and Sheetrock room by room, but my 1" of plaster is also my primary insulation (ha ha- not really a joke). My 2 little girls and myself also suffer from wicked dust allergies, so if it happens it won't be for a long time.
Any advice would be appreciated....
Thanks,
Andy
Marqed97 is offline   Reply With Quote
Old 03-09-2013, 02:23 PM   #2
Super Moderator
Use powdered easy sand--for the base coats--then switch to 'light weight' blue lid for the top coat---
scuff sanding the old paint helps with bonding----
Marqed97 (03-09-2013)
Old 03-09-2013, 06:18 PM   #3
Thanks Mike...I'll look for it on my next trip to the store.
Andy
Old 03-09-2013, 06:47 PM   #4
Originally Posted by Marqed97 View Post
Hey folks...
I've read through some of the threads related to plaster repair on here the last few days. I hate to rehash an already-addressed subject, but...there are some cracks and areas I've patched with Sheetrock. I've gotten them as close to level with the plaster as possible, trying to leave a little depth for whatever plaster type compound I'll use.
You may have missed the related thread where I wrote:
Originally Posted by Dorado View Post
For the rough area where plaster fell: Remove dust and plaster debris. Fill hole to just below surrounding surface with patching plaster. When almost dry, cut crosshatch pattern. When dry, spray with water and complete repair with joint compound.
From Ultimate Guide: Drywall, Third Edition
Dorado is offline   Reply With Quote
The Following User Says Thank You to Dorado For This Useful Post:
Old 03-09-2013, 08:18 PM   #5
That's a good idea too...must've missed that one. Thanks for reposting it! The crosshatch must give the joint compound a really good grip on the plaster.
plaster repair amakarevic Drywall & Plaster 5 07-23-2012 02:35 PM
Plaster Damage Repair heyitsthatgirl Drywall & Plaster 0 05-05-2011 10:41 PM
Plaster lath ceiling repair.... Klatimer Drywall & Plaster 2 05-04-2011 02:19 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 03:13 PM
