Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-04-2011, 07:41 AM   #1
Plaster lath ceiling repair....
I have a ceiling that had some water damage from an upstairs bath tub . For a temporary fix I was planning to cut out a sheet of drywall to repair it, but was thinking when I go to remove the area to be patched, will the rest of the ceiling come down with it, or is plaster strong enough to withstand the removal of a section of it .
Klatimer is offline   Reply With Quote
Old 05-04-2011, 07:54 AM   #2
Stay-at-home GC
Depends on the integrity of whats left.
Use a sawzall blade cut down to 1" to cut through the lathe in the area you want to remove. A full length saw blade will cut through your wiring
Pulling on the lath will break the keys down the line.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-04-2011, 02:19 PM   #3
You can cut out a section of plaster/lathe fairly easily, so long as the keys are sound in that area. It might be a good idea to brace up the plaster around the hole you are planning to make in it (some scrap lumber...) Also, keep in mind that once plaster gets wet, it takes a LONG time to dry...so make sure you get all the damaged product out of there. I would scab in a piece of sheet rock that was a bit thinner than the plaster/lathe combo and then build it up to match the existing surface.
Good luck!
1910NE is offline   Reply With Quote
plaster ceiling repair. patricias Drywall & Plaster 4 04-10-2011 01:35 PM
Plaster Wall Repair lierman44 Drywall & Plaster 4 03-09-2011 10:12 PM
Cutting a 6" hole in wood lath plaster ceiling dwoloz Drywall & Plaster 1 09-22-2010 09:07 PM
Ceiling Crack Repair Speckert Building & Construction 7 12-29-2008 11:03 AM
Ceiling fun --- New sheetrock meets old plaster! TivoTron Remodeling 8 02-13-2008 04:54 PM
