Plaster To Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 12:33 AM   #1
Plaster to drywall
We just relocated a door in our kitchen. The former door spot is now drywall that butts up to plaster. Problem is, the drywall is a tad...thicker? (sticks out further) than the plaster.
I know dh should have used 1/4 in. But he didn't listen, so now what? Any reasonable ways to deal with this?
toyarmy is offline   Reply With Quote
Old 08-04-2011, 09:30 AM   #2
Learning by Doing
Leah Frances's Avatar
Depends on several things. How big is the drywalled spot? How proud is the drywall (how far does it stick out from the plaster)? How long is the wall? We need some more details and how about some pics.
- If you've got a small enough thickness differential and enough wall space, you could tape the joint and feather the bejezus out of it.
- You could slap some 1/4 drywall up on the plastered portion. Again, dependent on how proud the new drywall is.
I'm guessing (unless dh drywalled the entire room) it will be easier to take the drywall down and do it correctly - either use thinner drywall or cut back your framing sufficiently to match.
Keep us updated.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
How do you intersect drywall (or in my case plaster) into tile on the same plane? Proby Kitchen & Bath Remodeling 5 08-02-2010 05:51 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Can you adhere drywall to plaster? whiskeykid Drywall & Plaster 9 08-15-2008 07:42 AM
Joining drywall and plaster pete1972 General DIY Discussions 5 10-28-2006 05:08 PM
