Plaster Ceiling - Want To Install Down/can Lighting With Least Mess/needed Patching - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 01:34 PM   #1
Plaster ceiling - want to install down/can lighting with least mess/needed patching
Does anyone have any suggestions on putting some canned lights/downlighting in a ceiling I have that currently does not have any lighting (completely flat ceiling)?
I am going to have to cut into the ceiling to run wire and place the cans, and I would like to hear some input on the best way to go about it. I wish I could put in the lights and not need to repatch the ceiling, but I don't think this is possible is it? The house is 1940s era and I am almost positive the ceiling is plaster...all the walls in the whole house are. Someone said it would probably be pretty pricey to get the plaster repatched, or at least more than it would be if it was just a sheetrock ceiling.
Any input is greatly appreciated!
Thanks!
Swaff
swaff is offline   Reply With Quote
Old 10-21-2010, 01:45 PM   #2
Phoenix
Is there attic above the ceiling ? If so, yes you should be able to do the wiring & figuring proper placement with out damaging anything. If no, then you will be looking at fixing plaster where ever wood is blocking the path of your wires.
Remember you can't put cans where trusses are when you are figuring out the placements of the cans this should be taken in to account.
Axecutioner-B is offline   Reply With Quote
Old 10-21-2010, 02:02 PM   #3
There is a bedroom above, so I am probably either working with 1x6 or maybe a little more. Thank you for your help!
Old 10-21-2010, 06:28 PM   #4
Phoenix
If thats the case then expect to do wall & ceiling repairs. You can minimize these by using the holes you cut for your cans to help fish the wires as much as possible.
Where is your power source?
Do you have switched power already in that ceiling or will you need to get switched power up the wall to a switch & then up to the ceiling?
The more you plan ahead the less repairs you may have to make at the end.
Personally i like the challenge of figuring out the most effecient way to run the wires with the least amount of drywall repair, i get mad at myself if when I'm all done i see any holes that i could've avoided making if i would have done something different.
HELP! lighting question for vaulted ceiling pauls General DIY Discussions 5 07-03-2010 04:53 PM
Is my contractor suggesting the correct way of redoing plaster ceiling? karenldee Building & Construction 7 10-23-2009 10:47 PM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
Lighting tip needed for vaulted ceiling wease Electrical 5 02-24-2007 11:49 PM
