Plaster Ceiling Repair. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 09:16 AM   #1
plaster ceiling repair.
I had beams in my living room removed. The nail holes were filled with spackle and more spackle was used to smooth the ceiling. A coarse roller was used to texterize the repaired portion of the ceiling. It was then painted twice. The repaired spackle is too corase and is very different from the rest of ceiling. How do I repair this mess? I had different contractors with various solutions and hugely different pricing. MY second floor small bathroom plaster ceiling has cracks and also needs repair. A suggestion of bead board was given which I do not especially like.
patricias is offline   Reply With Quote
Old 04-05-2011, 09:37 AM   #2
Super Master Painter
Ole34's Avatar
post a picture...............................
Ole34 is offline   Reply With Quote
Old 04-06-2011, 09:24 AM   #3
Drywall contractor
Rewards Points: 1,070
Agree that pics are necessary on the living room. As for the bath, hang a layer of drywall over the existing ceiling and finish to suit your taste....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-10-2011, 10:08 AM   #4
I had a few contractors in and have different options. Just replaster over the existing plaster by hand with an applied adhesive or spray on the new plaster. Will it stick? There is no cost difference to speak of.
For the bathroom, going to use the mesh to cover cracks and then spackle or replaster? Leaning toward replaster. Do not want to lose ceiling height.
Old 04-10-2011, 12:35 PM   #5
Drywall contractor
New drywall will only lower your ceiling 1/4" to 1/2" depending on what thickness drywall you use...
Textured Drywall Ceiling Repair TRACKER Drywall & Plaster 7 07-26-2010 05:55 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Plaster ceiling and drywall desrtrat Drywall & Plaster 13 10-08-2008 07:20 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Cracked Plaster Ceiling..... SSandecki Remodeling 1 12-23-2005 08:16 AM
