Peeling Paint On Ceilings - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 11:01 AM   #1
Just call me Andrew
Rewards Points: 1,020
Peeling paint on ceilings
My parents house (1974) has paint peeling near their light fixtures in many rooms (due to heat?), and in the bathrooms, the paint is peeling all over (moisture + heat?). I repainted the ceiling in the master bedroom, and after the paint dried, I went to do a second coat, and the roller pulled off the first coat of paint around the light fixture. New paint just will not adhere properly.
A painter thought that the drywall was not primed correctly when the house was built. Would sanding/priming work at this point, or better to re-sheetrock or put some type of spackle or plaster over trouble spots (or an entire bathroom ceiling?).
If I decide to sheetrock, can I use 3/8" and put it over top of the existing, or must I tear the old stuff down?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 03-12-2010, 11:45 AM   #2
are all fixtures to insulated space, no conditioned space above? maybe combo of moisture/heat. sounds like sanding and good prime first with cure time after prime.
The older I get the better I was
Old 03-12-2010, 11:48 AM   #3
Just call me Andrew
I think that most of the ceilings with the peeling near lights are on the second floor, unfinished attic above. I guess I can test sanding a small area, using a good primer (zinser 1-2-3?) then painting.
1 coat of primer or 2? How long do I let each coat cure?
Andrew
Old 03-12-2010, 11:59 AM   #4
one coat and if baths are being used two days. are areas insulated around fixtures, are they can lights?
Old 03-12-2010, 12:08 PM   #5
Just call me Andrew
No can lights, just flush or semi-flush mounts. There is insulation in the attic floor, above the ceilings in question.
Andrew
Old 03-12-2010, 01:08 PM   #6
Drywall contractor
Rewards Points: 1,070
Happened to me when I put up ceiling fans. The stipple around all of the light fixtures had turned loose. The heat does it. Scrape back to "solid" paint. Prime (oil primer will work best) to seal the edge. If there's an obvious line due to several coats of paint you may want to feather the edge with joint compound, then re-prime and paint. There's no need at all to re-sheetrock....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-12-2010, 02:07 PM   #7
Just call me Andrew
Thanks. Can you recommend a good primer?
Andrew
Old 03-12-2010, 02:54 PM   #8
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Zinsser cover stain would be my choice.
Kevin
Kevin M. is offline   Reply With Quote
Old 03-12-2010, 04:26 PM   #9
Drywall contractor
Or Kilz....
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
