Patching/texture Errant Box Location - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-14-2015, 08:32 PM   #1
Rewards Points: 516
Patching/texture errant box location
The wife wants the TV I hung lowered. Now I have to lower the data/electric box to keep it concealed. I kept the piece I cut out for the box so I'm going to put it right back where it was with a piece of backing. I do this a lot for homeowners and generals as I'm an electrician. Now that I'm a homeowner I'd like to learn how to patch my holes.
I'm looking for a near perfect finish. Is spackling the seam going to do it or can I do better?
I had a hole patched a year ago by a handyman and he did an awesome job. All I had to do was roll over it a few times with the matching color. My wife said he used a sponge to match texture...
I thought she meant a sanding sponge but IDK.
Adam
Arrow3030 is offline   Reply With Quote
Old 10-14-2015, 09:16 PM   #2
griz's Avatar
Rewards Points: 570
Install backing to hold patch.
Install patch.
Tape, top & skim.
Texture to match.
Paint to match.
griz is offline   Reply With Quote
The Following 2 Users Say Thank You to griz For This Useful Post:
Gymschu (10-15-2015), Sir MixAlot (10-15-2015)
Old 10-15-2015, 09:04 AM   #3
78Vette's Avatar
Rewards Points: 460
Sir MixAlot has a video on how to do this. Do a search on here.
78Vette is offline   Reply With Quote
The Following User Says Thank You to 78Vette For This Useful Post:
Old 10-15-2015, 05:01 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 726
Adam
What type of texture do you have on your wall Adam?
-Paul
PeckDrywallandPainting.com Twitter Facebook Linked in Google+ Youtube
Checkout some of my How to videos->How to Secrets from a Drywall Finisher
Sir MixAlot is offline   Reply With Quote
Old 10-15-2015, 11:58 PM   #5
Rewards Points: 1,481
Best solution I can see, -get a bigger TV, then you can move it down and still keep the box covered.
ChuckF. is offline   Reply With Quote
Old 10-16-2015, 04:39 PM   #6
Rewards Points: 5,894
No spackle, use joint compound.
Entering your general location can help with answering a lot of times
Old 10-16-2015, 04:40 PM   #7
No spackle, use joint compound, and paper tape.
Old 10-17-2015, 12:35 AM   #8
Rewards Points: 516
Thanks for the replies. I wish I could get a bigger TV!
I don't know how to appropriately name the texture. I'll check out the link to that post now that I know sirmix a lot isn't a 90's rapper.
The texture isn't flat and it isn't free trow and it definitely doesn't require a sprayer.
If I try this and it looks like Criss-cross can I fix it?
I like big butts
Old 10-17-2015, 08:03 AM   #9
Post a pic of the texture sounds like it may be stipple from the paint roller. There are so many different textures we really need to see it.
Old 10-20-2015, 08:06 PM   #10
Drywall contractor
Rewards Points: 1,056
Absolutely don't use spackle....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Definition of wet location lyle jessee Electrical 1 07-01-2011 08:57 PM
location of bath switches/ how far from shower mazey Electrical 2 06-29-2011 01:27 PM
Sump pit location cdyck Plumbing 1 04-29-2011 06:37 PM
hole for basement bathroom vent location jeeper Building & Construction 4 04-12-2009 11:25 AM
Well Pressure Switch Location dshcs Plumbing 4 02-05-2009 09:04 AM
