Patching Plaster And Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 03:46 PM   #1
Rewards Points: 190
Patching Plaster and Drywall
Hello. I just took down some tile in a room in my house. I have a few holes I need to patch up caused by the hammer. Then one area just crumbled about 3'x2'... My idea is to use 1/2 inch drywall but then when I was comparing the size. It looks like they put up 1/2 drywall but then plastered over it? Is this normal? How can I substitute the size difference?
ryanb4614 is offline   Reply With Quote
Old 12-06-2011, 10:44 AM   #2
retired union carpenter
Send a message via Yahoo to coupe
hi Ryan, it's probably gypsum backer board you're seeing behind plaster. this is normal now days-they used to use 1/4-3/8" lathing strips with 1/4" spaces between to force plaster into to hold it on wall. the part that crumbled, most likely got wet, due to bad grout? maybe you can build it up using 1/4" drywall glued to backer board, then cover using 5/8" drywall,gluing and screwing with 2 1/2" screws. if you can find the studs? if not, you can use rock to rock screws, countersink screws to through the drywall paper, Spackle two coats over screws and re tile
good luck
coupe
coupe is offline   Reply With Quote
Mating drywall to plaster on an inside corner acme54321 Drywall & Plaster 4 10-13-2010 11:09 PM
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 07:42 PM
Patching plaster in bathroom foothill Remodeling 2 06-02-2009 12:50 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
