Patching Paper Towel Dispenser In Bathroom? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 01:34 AM   #1
Rewards Points: 33
Patching paper towel dispenser in bathroom?
There's a paper towel dispenser above my vanity that was here when I moved in. It is basically a rectangle metal thing inside the wall and a cover. It's all rusted up and I just want it out. I think I'm going to remodel the sink/vanity/mirror area and that has to go. It's like 6 inches deep and a few inches tall and about 3-4 inches wide.
Elton20 is offline   Reply With Quote
Old 12-30-2012, 01:40 AM   #2
Rewards Points: 13,216
Ok so what's the question?
Remove it, patch the wall.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
federer (12-30-2012), gregzoll (12-31-2012)
Old 12-30-2012, 02:02 AM   #3
Rewards Points: 33
Question is how do I patch a hole that big
Old 12-30-2012, 02:12 AM   #4
Got a picture?
Most likly there's going to be studs visable once it's out, just cut the sheet rock back enough so expose 1/2 the stud, cut patch, screw in place with sheetrock screws, apply drywall compound with a 6" wide drywall knife then go over the seams with drywall tape and apply another thin layer of compound. Let it dry, wipe over it with the knife and apply another thin layer of compound.
It will take at least three layers to get it to the point you can sand it.
Now prime and paint two coats.
Windows on Wash (12-30-2012)
Old 12-31-2012, 12:50 AM   #5
Rewards Points: 33
here you go
Patching paper towel dispenser in bathroom?-photo-1.jpg   Patching paper towel dispenser in bathroom?-photo-2.jpg   Patching paper towel dispenser in bathroom?-photo-3.jpg   Patching paper towel dispenser in bathroom?-photo-4.jpg
Old 12-31-2012, 08:46 AM   #6
Rewards Points: 6,652
As stated before, remove, patch the hole. If you do not wish to make it bigger, you can attach a piece of 1/2" plywood on either side for you to secure the patch to.
Old 12-31-2012, 11:03 AM   #7
You could always try a hot patch out of DW, looks like a good candidate for one but if you've never done one before it probably would backfire on you.
take a piece of drywall about 14" x 14" measure hole area and cut away about 2" of dw all way around on backside leaving the paper in tact, what is left will be the area that fits into space, mud area on outside of hole and place the patch in the hole wiping excess mud off making sure all is flat and smooth as possible, let dry and keep applying mud until finished. like I said, someone who has done this as many times as I have its easy but a first timer ?? its not that hard really and its a quick fix.
"don't bend over in the garden, granny, them taters got eyes"
newfie49 is offline   Reply With Quote
Old 01-05-2013, 02:03 AM   #8
Rewards Points: 956
personally, with that much space i would convert it into something else, like a shelf or something.
federer is offline   Reply With Quote
Old 01-05-2013, 08:25 AM   #9
Rewards Points: 650
To add a drywall patch, cut the drywall back to the studs flush and add a cripple stud to each stud and possibly a header top and bottom. This will give you a good surface to work with for the drywall patch without fasteners being close to the edge.
Tags
dispenser , drywall , removal
HRV With Bathroom Stale Air Pickup??? 1BadBoy Building & Construction 10 06-17-2011 03:17 PM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 10:54 PM
bathroom towel racks ramonakc Interior Decorating 5 04-19-2009 02:59 AM
Paper or paint in bathroom? Halfpint Kitchen & Bath Remodeling 5 03-28-2009 01:12 AM
contact paper removal scatterbrain Remodeling 2 07-06-2008 08:57 AM
