-   -   Patching paper towel dispenser in bathroom? (http://www.diychatroom.com/f101/patching-paper-towel-dispenser-bathroom-167749/)
Elton20 12-30-2012 01:34 AM
There's a paper towel dispenser above my vanity that was here when I moved in. It is basically a rectangle metal thing inside the wall and a cover. It's all rusted up and I just want it out. I think I'm going to remodel the sink/vanity/mirror area and that has to go. It's like 6 inches deep and a few inches tall and about 3-4 inches wide.
joecaption 12-30-2012 01:40 AM
Ok so what's the question?
Remove it, patch the wall.
Elton20 12-30-2012 02:02 AM
Question is how do I patch a hole that big
joecaption 12-30-2012 02:12 AM
Got a picture?
Most likly there's going to be studs visable once it's out, just cut the sheet rock back enough so expose 1/2 the stud, cut patch, screw in place with sheetrock screws, apply drywall compound with a 6" wide drywall knife then go over the seams with drywall tape and apply another thin layer of compound. Let it dry, wipe over it with the knife and apply another thin layer of compound.
It will take at least three layers to get it to the point you can sand it.
Now prime and paint two coats.
Elton20 12-31-2012 12:50 AM
4 Attachment(s)
here you go
gregzoll 12-31-2012 08:46 AM
As stated before, remove, patch the hole. If you do not wish to make it bigger, you can attach a piece of 1/2" plywood on either side for you to secure the patch to.
newfie49 12-31-2012 11:03 AM
You could always try a hot patch out of DW, looks like a good candidate for one but if you've never done one before it probably would backfire on you.
take a piece of drywall about 14" x 14" measure hole area and cut away about 2" of dw all way around on backside leaving the paper in tact, what is left will be the area that fits into space, mud area on outside of hole and place the patch in the hole wiping excess mud off making sure all is flat and smooth as possible, let dry and keep applying mud until finished. like I said, someone who has done this as many times as I have its easy but a first timer ?? its not that hard really and its a quick fix.
federer 01-05-2013 02:03 AM
personally, with that much space i would convert it into something else, like a shelf or something.
SeniorSitizen 01-05-2013 08:25 AM
To add a drywall patch, cut the drywall back to the studs flush and add a cripple stud to each stud and possibly a header top and bottom. This will give you a good surface to work with for the drywall patch without fasteners being close to the edge.
