Patching Old Horsehair Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 11:26 AM   #1
amishboy23's Avatar
Patching old horsehair plaster
I am restoring an old 1850s home and am saving some of the plaster walls that are plastered directly on my 18" thick brick walls. What should I use? Plaster of Paris and then sand it down? I don't know what the best product would be. I won't shave my horses and do it the way they used to ha. Please provide your suggestions especially if you have had experience! Thanks
amishboy23 is offline   Reply With Quote
Old 01-14-2013, 12:42 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
For small areas, I use drywall compund. For larger areas, I use gauging plaster. Something like Gold Bond Super White. That assumes that the brown coat is intact. If not you need to put that down first and allow about an 1/8" for your finish coat. Plasterers are a dying breed. Finding real plaster can be a challenge sometimes. Since plaster for the past 70 years or more has been gypsum based, they haven't been shaving horses, so your hay burner is safe.
Old 01-14-2013, 03:27 PM   #3
automated tool pro
Rewards Points: 152
pictures?
drywallfinisher is offline   Reply With Quote
Old 01-15-2013, 04:37 PM   #4
Registered User
Rewards Points: 5,492
How to attach a photo to a post
http://www.plaster-wall-ceiling-solu...wall-tape.html
Gary
Old 01-16-2013, 03:20 PM   #5
Rewards Points: 1,294
danpik is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 03:59 AM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Patching plaster in bathroom foothill Remodeling 2 06-02-2009 12:50 AM
patching plaster skim coat thomase Building & Construction 2 06-30-2008 11:28 AM
