Patching Holes In The Drywall... - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 03:57 PM   #1
Patching holes in the drywall...
I have holes in my walls due to what looks like the curtain rod holders being ripped out of the walls....i went to homedepot with pics of all the holes next to a tape measure and was helped by someone who told me what i needed and what to do.
I got mesh tape, red dot westpac materials all purpose joint compound, sand paper, little saw, small drywall board, drywall screws and putty knives.
So I figured out how i wanted to do it and filled in all the holes and was very proud of myself! Not bad for a single grandma....and now....there are cracks developing in the compound as i dries....!!!??? I know this is only the first layer, but is this ok that this is happening? Has all my hard work been done in vain? Please help!
jdm17 is offline   Reply With Quote
Old 07-03-2011, 04:31 PM   #2
compound does that with a thicker application. try thin coats after the first one and you should be fine. when you are filling holes the first coat tends to be thicker.
Old 07-06-2011, 01:33 PM   #3
Drywall contractor
Rewards Points: 1,070
Yep, several thin coats are better than trying to "pile the mud on" to get it to cover....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Patching vinyl siding to "repair" small holes tomseeley Building & Construction 3 06-05-2011 10:12 AM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 02:49 PM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
'hard patching' blast holes in concrete warehouse floor shag_carpet Flooring 0 09-08-2010 05:29 PM
small holes in drywall mud kimmyb General DIY Discussions 5 01-26-2008 10:21 AM
