Patching Hole In Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 04:05 PM   #1
Patching hole in plaster
Finishing off my attic and need to patch this hole. The lath is still in tact. Would plaster patch work on a hole this size? Thanks for any input.
mjarema414 is offline   Reply With Quote
Old 05-27-2012, 08:28 PM   #2
Too Short? Cut it Again!
You can buy patching plaster in fairly small bags at a paint store. Not sure if a box store will carry it. Even a large bag will not be expensive. You should plan on a thick mix to fill in the space and then a skim coat layer to surface to the wall. Use a nice wide drywall knife or plaster trowel.
You could probably get away with a hot mud drywall patch too but it will heat and cool and therefore expand and shrink at a different rate than plaster.
I mix either for patches right in my drywall pan.
Make sure you remove any plaster around the hole that is not firmly attached to the lathe even if it means accomplishing a larger patch.
Be sure and let the plaster or drywall patch completely dry and cure before priming and painting it.
The Following User Says Thank You to user1007 For This Useful Post:
mjarema414 (05-29-2012)
Old 06-01-2012, 06:45 PM   #3
Drywall contractor
Rewards Points: 1,070
I've never used patching plaster, so I can't speak for that. I would cut a piece of drywall to fit the hole (as close to the shape of the hole as you can) and screw it to the lathe. You could shim it to get it as close as possible to the correct thickness. Then use mesh tape and setting type compound to finish. The final skim coat can be regular ready-mix. Just another option.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Patching plaster around light switches 2muttsmom Drywall & Plaster 13 08-20-2010 03:33 PM
patching existing hole in floor from former toilet drain ftlng Flooring 3 05-06-2010 10:24 AM
Prmier old plaster before patching? foothill Remodeling 4 06-06-2009 04:31 PM
Plaster wall - cutting out an access hole, but how to replace it? Steelmesh Building & Construction 8 11-07-2008 10:40 AM
