Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-17-2010, 11:18 AM   #1
Patching a firewall?
I had to cut a small (apprx. 3" x 5") hole in the OSB separating my garage from the living space. The OSB is also covered in 5/8" drywall (which I cut as well). I did this to help run a few wires for some new outlets.
Is it required that I patch the small hole in the OSB, or can I get away w/ just patching the drywall?
mopowers is offline   Reply With Quote
Old 03-17-2010, 01:34 PM   #2
Drywall contractor
Just patch the drywall, the OSB is not part of the fire code...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-17-2010, 11:29 PM   #3
Thanks!
Firewall Box mopowers Electrical 7 03-22-2010 11:02 PM
Need advice about waterproofing a firewall. angelo07 Building & Construction 12 01-01-2010 12:34 PM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 08:42 PM
Firewall in an existing house mjguff Building & Construction 2 03-11-2008 10:47 PM
