Patching Drywall At Floor Level... - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 09:56 AM   #1
Post
Patching drywall at floor level...
I am installing a new floor in my kitchen. As preperation I began to remove the baseboards. In some places the drywall behind the baseboard was still in good shape. I do have some places where it just crumbled. It was not caused by the removal of the baseboard, but I could tell that it was wet at somepoint in time. What is the best way to repair this drywall?
daballenger is offline   Reply With Quote
Old 05-06-2010, 05:21 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
dab, Welcome to the forum,
For a small area patch I use Fast Setand a 6" Joint Knife
First remove all wet or loose drywall
You will need some type of backer for the Fast Set
I mostly use scrap Luan plywood that I cut to fit behind the hole.
The drawing shows a minimalist overlap but if there is enough clearance between the edges of the hole and the studs I will make the backer large enough to put some support drywall screws through a good section of the drywall into the backer board.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-07-2010, 08:45 AM   #3
Drywall contractor
Rewards Points: 1,070
Cut the damaged drywall out to just below the level of the base. Install new drywall being sure to keep it 1/2" off the floor (base covers the joint, so no finishing needed). Install base holding it up off of the floor also. Your base shoe or 3/4 round (whichever you end up using) is the only thing that should touch the floor. Drywall (and trim) will wick water from mopping/spills and deteriorate over time. You can purchase composite shoe or 3/4 round to further prevent having to replace anything on down the line.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall - Durabond for patching a hole ccoulter350 Drywall & Plaster 6 03-06-2010 12:37 PM
Patching drywall 83trekker Drywall & Plaster 4 01-21-2010 10:55 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Prime before patching on drywall? DIYScott Remodeling 3 09-28-2007 09:19 PM
