Patched Drywall Is Thinner Than Original. I Need Suggestions. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 12:19 AM   #1
Patched Drywall is thinner than Original. I need Suggestions.
Hi Everyone,
My first time on the boards here. I admit I was looking around the internet for somewhere to ask my question and stumbled here. Hopefully I don't fall flat on my face.
My question is, I installed a new piece of drywall patch into a ceiling. The size is about 2 feet by 2 feet or so. It turns out that the piece I patched with his either too thin to begin with or I just screwed the patch piece in too high so now the patch piece is "pushed in" compared to the original. Are there any tips of how I can fill the gap where the "pushed in" look is showing? The difference is about 1/8th to 1/4 of an inch.
Any help will be appreciated. Thanks, Randy
thehip is offline   Reply With Quote
Old 07-28-2010, 06:55 AM   #2
DIY staff
Rewards Points: 7,174
Sounds like you may have used 1/2 inch to repair a 5/8 ceiling.
Either get thicker drywall--or fur down the thin piece with wood strips--
or fill in the void with several thin coats of drywall compound.
--Mike--
Old 07-28-2010, 09:54 AM   #3
--Mike--
I think Mike may have hit upon the issue with the 5/8" vs. 1/2" drywall. Around here anyway, it's common for ceilings to utilize 5/8", while the walls are 1/2", which would certainly account for the void you're experiencing in your ceiling patch if you did indeed use 1/2"
If the void is only about 1/8" or so, I think I'd tend to go with Mike's third option above of a few coats of compound to smooth everything out. I'm not saying that's the best method, but since you're going to need to feather out this joint anyway to blend with the remainder of your ceiling, it seems like a bit less work IMO.
H8Mondays is offline   Reply With Quote
Old 07-28-2010, 10:54 AM   #4
Thanks guys for the suggestions. I will try that third option and see how it goes.
Thanks again,
Randy
Old 07-28-2010, 11:19 AM   #5
Electrician
Proby's Avatar
I would use a setting compound like Sheetrock Easy Sand to fill it in. Since it's going to be pretty thick and over a wide area, the setting compound will work better since it has less chance of cracking. Then you could use normal premixed spackle for the second and third coats to make it pretty.
Proby is offline   Reply With Quote
Old 07-28-2010, 01:01 PM   #6
I will look up Sheetrock Easy Sand. Thanks.
Old 07-28-2010, 01:29 PM   #7
In case it helps in the search, the Easy Sand comes in a powder form, as opposed to a pre-mix in pails. Should be in the same area however and hopefully not too difficult to find. Then, just follow the directions on the bag for mixing in the water.
Old 08-01-2010, 10:52 AM   #8
Rewards Points: 530
I have done the same thing. I used 3/8 to patch 1/2 in my kitchen ceiling. Bad thing is, there is a light fixture in the center of the patch. I haven't fixed it yet. I will someday.
Old 08-01-2010, 12:04 PM   #9
Drywall contractor
Rewards Points: 1,070
Definitely use setting type compound for heavy fill coats. You can do a final skim with ready-mix.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-02-2010, 12:34 PM   #10
Rewards Points: 558
--Mike--
Yeah I was thinking the same thing...
epson is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
What's the best way to patch drywall tuchodi Drywall & Plaster 2 06-18-2010 10:07 PM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 05:17 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
