-   -   Patched Drywall is thinner than Original. I need Suggestions. (http://www.diychatroom.com/f101/patched-drywall-thinner-than-original-i-need-suggestions-77315/)
thehip 07-27-2010 11:19 PM
Hi Everyone,
My first time on the boards here. I admit I was looking around the internet for somewhere to ask my question and stumbled here. Hopefully I don't fall flat on my face. :)
My question is, I installed a new piece of drywall patch into a ceiling. The size is about 2 feet by 2 feet or so. It turns out that the piece I patched with his either too thin to begin with or I just screwed the patch piece in too high so now the patch piece is "pushed in" compared to the original. Are there any tips of how I can fill the gap where the "pushed in" look is showing? The difference is about 1/8th to 1/4 of an inch.
Any help will be appreciated. Thanks, Randy
oh'mike 07-28-2010 05:55 AM
Sounds like you may have used 1/2 inch to repair a 5/8 ceiling.
Either get thicker drywall--or fur down the thin piece with wood strips--
or fill in the void with several thin coats of drywall compound.
--Mike--
H8Mondays 07-28-2010 08:54 AM
--Mike--
I think Mike may have hit upon the issue with the 5/8" vs. 1/2" drywall. Around here anyway, it's common for ceilings to utilize 5/8", while the walls are 1/2", which would certainly account for the void you're experiencing in your ceiling patch if you did indeed use 1/2"
If the void is only about 1/8" or so, I think I'd tend to go with Mike's third option above of a few coats of compound to smooth everything out. I'm not saying that's the best method, but since you're going to need to feather out this joint anyway to blend with the remainder of your ceiling, it seems like a bit less work IMO.
thehip 07-28-2010 09:54 AM
Thanks guys for the suggestions. I will try that third option and see how it goes.
Thanks again,
Randy
Proby 07-28-2010 10:19 AM
I would use a setting compound like Sheetrock Easy Sand to fill it in. Since it's going to be pretty thick and over a wide area, the setting compound will work better since it has less chance of cracking. Then you could use normal premixed spackle for the second and third coats to make it pretty.
thehip 07-28-2010 12:01 PM
I will look up Sheetrock Easy Sand. Thanks.
H8Mondays 07-28-2010 12:29 PM
In case it helps in the search, the Easy Sand comes in a powder form, as opposed to a pre-mix in pails. Should be in the same area however and hopefully not too difficult to find. Then, just follow the directions on the bag for mixing in the water.
boman47k 08-01-2010 09:52 AM
I have done the same thing. I used 3/8 to patch 1/2 in my kitchen ceiling. Bad thing is, there is a light fixture in the center of the patch. I haven't fixed it yet. I will someday. :whistling2:
bjbatlanta 08-01-2010 11:04 AM
Definitely use setting type compound for heavy fill coats. You can do a final skim with ready-mix.
epson 08-02-2010 11:34 AM
--Mike--
Yeah I was thinking the same thing...
