I tried using butterfly drywall anchors in my mud room to hang bicycles, as there were no studs at the right height. As you can see, it didn't work out.
Any suggestions to create a proper anchor for the bikes? Does it make sense to cut out a larger horizontal section of the drywall and put a 2X4 in before replacing the drywall?
I'm not clear if that's ceiling or wall I'm looking at. Anyway, if it's wall for example and you don't have studs in a good position, you can put up a nice trim board, say 1X6" pine 4-6' long, and screw that solidly into the studs where the studs are. Then you can put your hooks or whatever anywhere along the trim board.
Thanks Folks. yeah it's the wall you're looking it. Since I have to repair that hole anyway, I think I'm just going to cut a bigger section of the drywall out and screw some 2X4s between the studs to act as anchors.
Cut out the damaged drywall and fasten two spruce 2X2's to the adjacent wall studs 1 3/16 behind the face of the existing drywall.
Now, screw 3/4 inch plywood (which will be 11/16 inch thick) to the spruce "nailers".
Then, use drywall screws to cover the hole with drywall and still be flush with the surrounding wall.
Apply self adhesive fiberglass mesh drywall tape to the joints, mud the joints, sand smooth, prime and paint.
Now you can drill through the drywall into the plywood and screw in a strong hook or whatever you need to support those bicycles.
Now
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
