Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-22-2013, 09:58 AM   #1
paper tape or mesh tape
i ran out of paper tape. i have some mesh tape that someone gave to me.
ive never used mesh tape. is it good or will i get crappy results?
echobravo is offline   Reply With Quote
Old 01-22-2013, 10:07 AM   #2
It's not crappy, just a whole lot more work to cover it up with out the fiber showing through.
Going to have to have up to a 12" wide joint so there's not a hump.
Old 01-22-2013, 07:38 PM   #3
paper overall is better. when using mesh you should use a setting compound for atleast the first coat to avoid cracking. if you see you are running low on paper tape use it for your butt joints and inside corners then use the mesh for the flats so you dont have to skim like what joecaption said.
princelake is offline   Reply With Quote
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 10:09 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 09:36 AM
tape and float - tape is coming off! samf Remodeling 3 09-29-2006 09:09 AM
