Paper Faced Corner Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 09:03 AM   #1
Paper faced corner bead
Hi there. I bought a bunch of paper faced outside corner bead in 10ft lengths. I have long sections of bulk head in my basement and am wondering if I can splice the corner bead together or do I need to use tape for the long sections? Any ideas or help would be much appreciated. Thank for Any info
Rambo1982 is offline   Reply With Quote
Old 04-23-2013, 09:30 AM   #2
Rewards Points: 626
post a photo
also look in to trimtex vinyl corner bead for something like that. Oh and you can't buy TrimTex products at your local Box store you have to buy it from a sheetrock supply shop.
Nailbags is offline   Reply With Quote
Old 04-23-2013, 10:47 AM   #3
Rewards Points: 672
By "splice" you mean butt two pieces next to each other when you don't have a long enough piece to run the length? I believe so, but I will let a drywall expert pipe in.
In response to Nailbags: aren't vinyl corner beads harder to mud and paint than paper/metal corner beads?
B
Beepster is offline   Reply With Quote
Old 04-23-2013, 11:26 AM   #4
Sometimes tape alone is used (I read that's the traditional method) so I don't see a problem with butting two sections of bead. I'd probably put tape over the butt.
Dorado is offline   Reply With Quote
The Following User Says Thank You to Dorado For This Useful Post:
Rambo1982 (04-23-2013)
Old 04-23-2013, 01:36 PM   #5
Rewards Points: 744
Don't use the paper-faced corner bead in areas that could possibly get bumped. It's not as strong.
Whenever I've needed to butt two pieces of corner bead, I have not spliced over it with paper tape. I don't think it would hurt to do so, however.
Seattle2k is offline   Reply With Quote
Old 04-23-2013, 02:54 PM   #6
I just did a bulk head in my basement and had to butt 2 pieces of the paper faced corner bead together, can't even tell.
bova80 is offline   Reply With Quote
The Following User Says Thank You to bova80 For This Useful Post:
Nailbags (04-30-2013)
Old 04-23-2013, 06:21 PM   #7
Awesome. That's good news
Old 04-30-2013, 10:14 AM   #8
Rewards Points: 626
B
No they are not. if you use the right ones not the ones out the Orange or blue stores.
Old 04-30-2013, 01:38 PM   #9
retired union carpenter
Send a message via Yahoo to coupe
personally, I've never been a fan of paper anything other than tape. for the purpose it was designed for, inside corners and joints. unless, it's paper L bead where it's not subjected to exposure.
that being said, yes you can butt paper bead joints. using a splice piece say 6"7" placed under the joint to keep pieces even. and, no vinyl beads will not keep paint any better than the bumper on your car or resin outdoor furniture or siding. it just don't bond to vinyl it'll look okay for a couple/few days till weather starts popping paint off in flakes the size of pennies! there is a reason vinyl, and resin are manufactured with color throughout. if it gets scratched? it's the same color.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Wrapping a 3/4 Ledger - Paper Faced Metal Corner, No Coat 450 or L Bead mobiledynamics Drywall & Plaster 1 03-29-2012 10:17 AM
Corner bead wraiththe Tiling, ceramics, marble 0 12-19-2011 10:37 AM
corner bead crack igneous Drywall & Plaster 4 02-08-2011 01:11 PM
proper method for paper faced drywall corners rocketdoctor Drywall & Plaster 2 12-06-2009 10:14 AM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 06:09 PM
