Paneling To Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 10:11 PM   #1
Paneling to drywall
We are removing paneling and installing drywall. Do we have to install all new door jambs to account for the thicker wall we are now going to have?
annee235 is offline   Reply With Quote
Old 01-30-2010, 10:41 PM   #2
Rewards Points: 160
Is there any way to remove the panelling and get thin enough drywall that you might be able to skip new jambs?
Matters on how many jams you would need to replace, but if its thincker then you'd have to modify the jambs
hellothere123 is offline   Reply With Quote
Old 01-31-2010, 12:17 AM   #3
jlhaslip's Avatar
Rewards Points: 386
you can nail on jamb extensions of a suitable thickness to have the jamb about 1/16th of an inch proud of the drywall.
trust me, the 16th will make the casing easier to install.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-04-2010, 11:21 AM   #4
Drywall contractor
Rewards Points: 1,068
If they are pre-hung doors they should have a "slip" jamb which will make up the difference in thickness. You will have to get the jamb apart rather than just pull the casing off.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
uneven wood paneling joefromcal Carpentry 6 04-30-2009 10:50 PM
paneling replacement options tbinstl Remodeling 1 01-17-2009 09:44 AM
Removal of paneling and drop ceiling margog85 Remodeling 14 07-25-2008 04:13 PM
Basement Mod from Paneling to Drywall kilgoretrout Remodeling 2 01-14-2008 09:58 AM
Drywall over drywall? And a bonus flooring question! perpetual98 Remodeling 18 01-02-2008 11:36 AM
