Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-11-2009, 03:45 PM   #1
sciuttochick's Avatar
Painting Plaster with Drywall patches
I am getting ready to paint my house. We fixed some spots in the plaster with brand new drywall. How do we prime the house so that the paint looks consistant? I was told that all we need is one coat of primer and one coat of paint. PLEASE HELP!!!!!!!!!!!!!!!!!!
sciuttochick is offline   Reply With Quote
Old 01-11-2009, 04:09 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
One coat quality primer, two coats quality paint
Be sure the patches are as smooth as possible and feathered nicely before prime
Paint colors, it doesn't fill
If, after the primer, some obvious uneven patches appear (this often makes the "not quite" areas show up clearly), then skim some more joint compound, feather sand, wipe clean of dust, and spot prime the raw j/c areas before painting
(It will be much easier to repair any "iffy" areas before you start applying paint)
slickshift is offline   Reply With Quote
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 03:20 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
