Painting Over Platched Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 05:44 PM   #1
Rewards Points: 14
Painting over platched drywall
I patched some holes and protruding nail heads with joint compound and finished.I painted the white wall with red latex paint.The paint covered the the old paint well except for the patched places where the compound blead through.I put two more coats on with the same result.Now the entire wall is cracked.Looks like the bottom of a dried up lake.Any ideas what went wrong?
Thanks, Glenn Archer
G Archer is offline   Reply With Quote
Old 01-20-2009, 07:46 PM   #2
Did you prime the patch?
slickracer is offline   Reply With Quote
Old 01-21-2009, 05:11 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Sounds like you didn't prime the patches
Reds can take three coats
Poor quality red paints (ie: Behr) can take 5 - 7 coats
If the whole thing is cracked, you probably have some other issues
(not letting it dry before re-coating, improper prep/contamination, latex over oil, etc...)
slickshift is offline   Reply With Quote
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 04:12 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
