Painting Over Drywall Bubble - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-06-2009, 10:23 AM   #1
Painting over drywall bubble
Hey Guys,
Does anyone have a suggestion for a drywall joint that has slightly bubbled? I did not notice the bubble until I had already put 2 coats of primer on it. Also, if I can't fix the bubble, would white paint or beige paint hide this imperfection better?
FYI: This is a small one room job and as I live in a very rural area, I could not get a pro to even look at the job, hence why I am doing it myself.
Thank you.
AlSmith is offline   Reply With Quote
Old 06-06-2009, 12:11 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Do what you can to fix the bubble. It will be well worth it. Lighter and flatter paint hide imperfections better.
Old 06-06-2009, 06:06 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Cut out the bubble
Smooth out the repair with joint compound
Feather sand
Prime repair
Coat wall with two coats quality paint
slickshift is offline   Reply With Quote
Painting Drywall Patch markospencer Drywall & Plaster 3 12-30-2008 06:25 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 01:54 AM
