Painting New Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 02:23 AM   #1
painting new drywall
Would it be okay to use one of the new paint products with the primer already mixed in to paint my newly drywalled ceiling?
dtape is offline   Reply With Quote
Old 03-09-2011, 02:39 AM   #2
thats a good question.we just painted new drywall afer a pocket door install,but used primer we already had.went to HD to purchase paint for that wall and saw these new paint products but didn't ask.
jeff
jeffski1 is offline   Reply With Quote
Old 03-09-2011, 02:56 AM   #3
I would recommend against it.
Drywall primer is cheap and goes pretty far. Those primer included products are mainly for coverage as they have a very high zinc oxide or other high coverage additive mixed in to my knowledge. You would be best served by using drywall primer to seal the paper backing and provide an even surface for the paint with good adhesion. My issue is that it might suck up a lot of paint unless you're really trying to save time over money.
cschwehr is offline   Reply With Quote
Old 03-09-2011, 08:49 AM   #4
Old School
Willie T's Avatar
Priming with the d/w primer serves another purpose too. It quickly shows up any problem areas with your finishing and unlike paint can be easily sanded and refinished to achieve perfection prior to painting.
Willie T
Old 03-09-2011, 05:39 PM   #5
Drywall contractor
Rewards Points: 1,070
And it evens out the absorption of the finish coat of paint to keep the joints from "flashing"...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-11-2011, 12:31 AM   #6
Don't you think that it would not ruin your previous paint and would not damage the wall. What i would suggest you is to check it on minimum and then go for whole! Luck!
Watson63 is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
painting bathroom - primer for greenboard and hardiebacker? carrotguy Remodeling 5 06-23-2008 03:50 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
