Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-29-2008, 01:01 PM   #1
Painting Drywall Patch
Hi,
I just finished patching a drywall. I primed over the patch, and finally painted over with the matching top coat. However, I do notice that the patch does not blend with the existing wall paint texture. The patch looks too smooth after painting and is easily visible. I'm using a standard smooth paint roller. How do I make the patch blend with the existing wall texture. Is there a specific paint roller I should be using that builds up the paint texture.
Thanks.
markospencer is offline   Reply With Quote
Old 12-29-2008, 06:53 PM   #2
Drywall contractor
A longer nap roller should even out the "texture" from the roller. Hard to say for sure, but probably a 3/8" - 1/2" would be minimal. It may be even heavier than that. If the paint color is off even a bit, you may need to paint the whole wall also. Sort of a trial and error thing, unless some of the painting pros have other suggestions.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-29-2008, 08:44 PM   #3
Workaholic's Avatar
Try using a 1/2" nap - 3/4" nap. If this does not have satisfying results repaint the entire wall.
Sean
Workaholic is offline   Reply With Quote
Old 12-30-2008, 06:25 AM   #4
I have had the same problem. I fixed it by priming the patches with a nice, thick primer and a roller prior to the topcoat. (I used SW PrepRite ProBlock Latex.) This made the patches invisible. It also helped to prevent gloss-shift in the final coat (I think.)
SirWired
sirwired is offline   Reply With Quote
Best way to patch holes in drywall CowboyAndy Drywall & Plaster 5 12-18-2008 12:55 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 01:54 AM
