Painting A California Knockdown Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 09:52 AM   #1
Captain C
Painting a California Knockdown ceiling
I first primed the drywall ceiling with 2 coats of latex ceiling white. Then the knockdown application was completed and now dry.I now want to paint the ceiling white.
My question is, can I use a good quality latex paint or do I have to use a oil base. Thanking you in advance.
Jim Caley is offline   Reply With Quote
Old 02-27-2010, 10:29 AM   #2
Old School
Willie T's Avatar
Why do you want to use oil?
Willie T
Old 02-27-2010, 10:56 AM   #3
Too Short? Cut it Again!
For future reference, you should have used a primer, not paint under the texture but that is water under the bridge now. Primer and paint are two different things, with different properties, and for different purposes.
No reason at all you need oil based over the knockdown if it is just drywall compound? You should prime before you paint though to seal the knockdown and give a nice surface for the paint to adhere. I would just use a quality latex primer, than two coats of finish.
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Problem Painting Ceiling! Please Help! p00lbys Painting 3 06-06-2009 04:59 PM
Ceiling Painting woodchuck1 Painting 3 12-19-2007 09:54 PM
california knockdown stucco bottrell22 Painting 6 09-28-2007 07:57 AM
Painting textured ceiling Unregistered Painting 5 06-17-2005 01:27 PM
