Painting Back Of Drywall - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 05:26 PM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Originally Posted by I need help now View Post
I installed the wallpaper in the bathroom which is coming off without problems. I knew what I was doing when I hung it! All the glue is off the bedroom wall so skim coat should stick great.
The bathroom wall will get primed with Kilz 2 times before any paint ever touches it. I did this in another room in the past and it worked great since I could not get all the glue residual off. The wall was nice and smooth to paint after Kilz.
Kilz oil I hope.
Old 11-07-2011, 12:01 PM   #17
Rewards Points: 4,780
Originally Posted by Gymschu View Post
Can't believe anyone in their right mind would install drywall wrong side out. What a nightmare it would have been to finish the joints.
Whoa, this is getting way blown out of proportion. There is no "nightmare" - people do butt joints on drywall installed the right way all day long.
There is no problem here. A coat of Gardz would be great, but if you're using flat paint, a couple coats of that would look fine too.
jeffnc is offline   Reply With Quote
Old 11-07-2011, 07:39 PM   #18
Too Short? Cut it Again!
Hugh? You are suggesting skipping a primer/sealer? Over potentially lingering wallpaper paste?
Old 11-07-2011, 07:42 PM   #19
No, I might have missed the context along the way here. I was talking about plain drywall paper.
Old 11-07-2011, 09:44 PM   #20
Who is Hugh?
Old 11-08-2011, 06:07 AM   #21
chrisn's Avatar
Rewards Points: 122
Originally Posted by jsheridan View Post
Who is Hugh?
I believe that has been asked and answered elsewhere.
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (11-08-2011)
Old 11-08-2011, 07:49 AM   #22
Is you're own astute words, read the post, they were talking about the backside of drywall.
Not sure what "is you're own astute words" means, but yes I'm aware we're talking about the backside of drywall. Now why exactly would making joints on the backside of drywall be a "nightmare"? There are no tapered edges, but why would it be any worse than doing any regular butt joint?
Old 11-08-2011, 08:06 AM   #23
Gymschu's Avatar
Rewards Points: 206
Uh, Jeff, have you ever finished the backside of OLD drywall? The old drywall from the 50's and 60's had a very coarse backing made up of the thick brown paper, and, yes, it would be a nightmare to try and finish it properly. Sure it could be done, but with much more effort than doing the front side.
Gymschu is online now   Reply With Quote
Old 11-08-2011, 08:24 AM   #24
Not really relevant here. Did you read what the OP wrote? "The house was build in 1986 so this should not have been done this way, drywall then was the same as now white on the side facing the room."
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Venitian plaster faux painting using drywall compound? crankcase Painting 3 02-18-2011 08:51 PM
Painting drywall G Archer Painting 3 03-28-2009 09:18 AM
Painting over platched drywall G Archer Drywall & Plaster 2 01-21-2009 06:11 PM
Painting drywall in garage Rod Painting 5 08-12-2005 07:36 PM
