Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-30-2011, 05:05 PM   #1
painting back of drywall
Can I paint the back of drywall it was installed that way. I found this when taking off the wallpaper.
I need help now is offline   Reply With Quote
Old 10-30-2011, 09:30 PM   #2
the drywall was installed the wrong way? You can paint it but the texture will look off...probably best to reinstall or cover with drywall is my suggestion
hellothere123 is offline   Reply With Quote
Old 10-30-2011, 10:52 PM   #3
I have a chair rail 33 inch high, below is the problem area. I thought of that too but since drywall is 1/2 inch thick it would not work. I guess I would have to take it out and place new drywall, oh what a bummer.
Home Depot paint guy said use a drywall primer.
Old 10-30-2011, 11:41 PM   #4
sdsester's Avatar
Wow. An HD person actually offered halfway decent advice.
Use a thick nap roller and a paint store, not HD, high bond primer though. It will look fine.
Just curious. How did noone notice they were hanging drywall the wrong side facing forward?
sdsester is offline   Reply With Quote
Old 10-31-2011, 12:06 AM   #5
I was removing wallpaper below the chair rail. I used the steam method first and everything came off incl. paint which left a white powder behind. Than I tried wetting with the same results. I thought it looked wrong so I went to HD and sure enough, the cardboard side is the back and that is what I am looking at now.
Old 10-31-2011, 01:40 AM   #6
sdsester's Avatar
So prime it as suggested. Two coats of finish paint and few but us on this site will ever know. The idiot drywallers did not tape it from the other side of the studs right? You do have nice taped and mudded seams? You are in big trouble if they climbed inside your 4" walls and finished the proper side screwed to the studs.
By the way, and I should have thought of this. You mentioned removing wallpaper and chair rail. Very early wallboards did have the company name and all that crap on the front side of the material. Is your home vintage? If it is post 1920 or so? Or new construction. God help us all for hanging the board backside facing out.
Old 10-31-2011, 07:45 AM   #7
Are you keeping the chair rail? If so, the break in the plane of the wall is going to mask a lot of the difference between the finish above and below. Not saying its right, just an observation. Another option, before you rip down and replace drywall (again, below the chair rail,) would be to install bead board/ wainscoting. You can find the stuff almost anywhere, and I think 3/8ths would work for your needs.
Good luck, and post some pictures if you can.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 10-31-2011, 11:52 AM   #8
Thank you both. The house was build in 1986 so this should not have been done this way, drywall then was the same as now white on the side facing the room. I guess the workmen just slammed the stuff in and the homeowner then did not check up as the building was going on or did not know it was wrong. I am keeping the chair rail had purchased two different shades of lavender prior to starting the wallpaper removal. Darker under the rail, rail snow white. I am still going strong but getting very tired of this removal. Pulled off wallpaper in the bathroom today and it came off without a hitch just need to prime before painting. By now you can tell I am doing several rooms, lucky me!! It will be worth it. I am not a professional but think sometimes I do a better job since my time is not $$$ like a contractor/painter. I will do it right the first time so there is no cont. fixing. Thanks again !!!
Old 10-31-2011, 12:00 PM   #9
Military Mom of 4
Snav's Avatar
Are you sure it's the 'back' - brand skins have changed over time. . . certain older drywall sheeting had a brown paper - but it's not the 'back' of it. . . but would be treated like any other wall-surface: prime first.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 10-31-2011, 12:35 PM   #10
Gymschu's Avatar
Can't believe anyone in their right mind would install drywall wrong side out. What a nightmare it would have been to finish the joints. I'm guessing you pulled the paper facing off the FRONT of the drywall exposing the brown paper that holds the gypsum in place. This may be an instance where priming and skimming the walls comes into play.
The Following 3 Users Say Thank You to Gymschu For This Useful Post:
1910NE (10-31-2011), boman47k (10-31-2011), chrisn (11-01-2011)
Old 10-31-2011, 09:03 PM   #11
I think I might would test a small area of the "brown paper" with water and a scraper. That steamer may have done more than you wanted it to.
The Following User Says Thank You to boman47k For This Useful Post:
Gymschu (10-31-2011)
Old 10-31-2011, 10:05 PM   #12
My drywall is getting new life tomorrow, skimcoat by a contractor with texture to near match? of the wall above the chair rail.
I just took the wallpaper in the bath off, came off just pulling but now I have some areas with glue residue. I guess I have to get the remover from HD. Tried washing off, I will be there forever. No wallpaper ever again I tell ya!!!
Old 11-01-2011, 04:03 AM   #13
paper hanger and painter
chrisn's Avatar
Now that's just wrong
It is just this attitude that I am not hanging any wall paper.
If the paper had been installed properly, with the proper PASTE, it would not be a problem removing. You are only having problems because a lazy, stupid, worthless, good for nothing" installer " did a crappy job.
PS Be SURE you either, get all the adhesive off the walls and or use an oil primer of better yet Gardz before painting. The Gardz should be applied before and after the skim coating also.
Old 11-01-2011, 09:43 AM   #14
Little off subject, but does anyone else see the tiny blue box right below the tag box that takes you to a Behr ad?
Old 11-01-2011, 09:54 AM   #15
I installed the wallpaper in the bathroom which is coming off without problems. I knew what I was doing when I hung it! All the glue is off the bedroom wall so skim coat should stick great.
The bathroom wall will get primed with Kilz 2 times before any paint ever touches it. I did this in another room in the past and it worked great since I could not get all the glue residual off. The wall was nice and smooth to paint after Kilz.
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Venitian plaster faux painting using drywall compound? crankcase Painting 3 02-18-2011 08:51 PM
Painting drywall G Archer Painting 3 03-28-2009 09:18 AM
Painting over platched drywall G Archer Drywall & Plaster 2 01-21-2009 06:11 PM
Painting drywall in garage Rod Painting 5 08-12-2005 07:36 PM
