Painted Popcorn Impossible - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 12:21 AM   #1
Painted popcorn impossible
I've sprayed a good amount of hot water/fabric softner onto my painted popcorn ceilings in hopes of easily scraping them off... not even close! They are just as hard as they were before, but now wet. I know of the option to put new drywall over it and start from scratch but I'd rather not. Could I just apply mud with a hopper and try to do a knockdown texture over it? Any advice would help. Thanks.
newdiyfer is offline   Reply With Quote
Old 02-07-2010, 08:22 AM   #2
Too Short? Cut it Again!
You could try a knockdown texture over it if you are sure the evil stuff is really stuck up there. You will have a mess if the popcorn and knowdown stuck to it starts coming loose though. I would be tempted to prime before the knockdown finish to aid adhesion.
Old 02-08-2010, 02:21 PM   #3
Drywall contractor
Rewards Points: 1,070
Try a hard scraper to knock the texture off (floor scraper works well). Once you get it started you may be able to get under it to get it off. Then you may be able to sand it reasonably smooth and skim..
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-08-2010, 02:25 PM   #4
Military Mom of 4
Snav's Avatar
Yeah, like BJ said - Just tarp up your doorways, get a face mask, get a set of scrapers, and be done with it.
I did my whole living room and bathroom like that and am glad - it was an annoying mess but well worth it.
They also sell panels that you apply over top of popcorn that are decorative - not cheap - but pretty.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Removing painted popcorn texture from ceiling Norva Drywall & Plaster 5 02-02-2010 12:24 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
Removing painted popcorn finish tubguy Painting 4 06-23-2008 10:11 PM
Removing painted popcorn texture from ceiling cnielsen4130 Remodeling 8 10-08-2007 12:21 AM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 05:36 AM
