Painted Over Wallpaper Paste - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-20-2014, 04:23 PM   #1
I'm not sure if this question belongs in the painting forum, or the drywall forum but, I'm trying here first.
In a house I purchased two years ago I have, what seems to be, wallpaper paste that was not removed prior to painting. The result is: painted walls that have multiple textures under the paint that are not common to a home. I'm trying to determine what the best course of action is.
Rocking over with 1/4 isn't an option in all areas because of a stair railing, a knee wall, corners where door casing pretty much butts up to adjacent walls, and so on.
Tearing everything out would work. It would obviously get me to a smooth surface and possibly give me the cleanest look. But, if there's a cleaner method, I'd like to know what it is.
I once had an old timer drywall guy tell me about a trick he sometimes used on rough walls. Joint compound thinned down and rolled on with a heavy nap paint roller.
I had another old timer recommend using a 12" flat trowel (I've been a tile guy for 20 years and I have a few flat trowels for skimming floors/walls and doing mud work) and skimming the surface.
I'm a tile guy, not a painter or drywaller, so I have some skills. Do any of the above options seem possible? Are there other tricks that I could use in this situation?
sterlingmosaics is offline   Reply With Quote
Old 02-20-2014, 04:30 PM   #2
Gymschu's Avatar
Rewards Points: 838
Dozens and dozens of threads on here about skim coating. Here's ONE example:
What is "skim coating" ?
Basically you thin down joint compound with water to a pancake batter consistency. You can use a paint roller to roll the mud onto the walls. Then use your trowel or a broad knife to smooth it out. Allow the first coat to dry. Once dry, remove any ridges you created by sanding or using your broad knife as a scraper. Apply a 2nd coat. Allow to dry. Then use a sanding sponge, a pole sander, or whatever sanding method is comfortable for you. Sand the compound so it is smooth. Wipe down/vacuum dust. Apply a drywall primer and you are ready for paint.
That's about the only option you have at this point. There's no way to remove that paste once it has been painted over.
Keep reading on here. Like I said there is tons of info on here about skim coating. Also check out the many youtube videos about skim coating.
The Following User Says Thank You to Gymschu For This Useful Post:
sterlingmosaics (02-20-2014)
Old 02-20-2014, 04:49 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
wouldn't it be a lot easier to take a sander to it?
Old 02-20-2014, 04:51 PM   #4
Rewards Points: 582
do you really want textered walls..
Old 02-20-2014, 04:53 PM   #5
Sanding didn't do anything to it. Neither did scraping it w/ a wallpaper scraper til by arms gave out.
Old 02-20-2014, 04:54 PM   #6
No. I don't want textured walls. I want flat painted walls.
The Following User Says Thank You to sterlingmosaics For This Useful Post:
ben's plumbing (02-20-2014)
Old 02-20-2014, 05:02 PM   #7
Gymschu's Avatar
Rewards Points: 838
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
ben's plumbing (02-20-2014), sterlingmosaics (02-20-2014)
Old 02-20-2014, 05:05 PM   #8
Rewards Points: 582
well then you may have to skim coat it???? ben sr
Old 02-21-2014, 03:59 AM   #9
chrisn's Avatar
Rewards Points: 394
you need an orbital sander with 80 grit paper
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (02-21-2014)
Old 02-21-2014, 06:34 AM   #10
Rewards Points: 5,974
Skim coat with the 12" trowel and the ultra lite mud in the bucket with the puke green lid. The thinned down paint roller method is for wall with minor flaws or that are almost smooth and you just want to even it out.
Old 02-21-2014, 06:52 AM   #11
I'm re-painting a bedroom right now and had to deal with the same problem. Simple solution. Water, paint brush. towel for drying and a wide spackle knife. Here's a link to a Youtube video that help me:
Let's hope whoever put up the wallpaper prepped the walls with sizing properly. Good Luck.
DIYRemodeler is offline   Reply With Quote
Old 02-21-2014, 06:59 AM   #12
Disregard my post above. Wasn't processing that walls were painted already. (It's early.) I would recommend skimming coating as suggested by previous posters. You'll still have to do some sanding though to smooth everything out.
Old 02-21-2014, 04:51 PM   #13
chrisn's Avatar
Rewards Points: 394
if they prepped the walls with actual sizing, then you are screwed,
twice
Tags
drywall , paint , paste , skim , wallpaper
Painted wallpaper takedown? Bennylava Painting 10 06-13-2013 08:54 PM
I painted over wallpaper glue wardo Painting 2 10-29-2012 04:58 PM
not wallpaper paste but stretchy tape Startingover Painting 12 10-11-2012 05:27 PM
skim coat over wallpaper paste residue bubbler Drywall & Plaster 6 04-17-2012 02:55 AM
Painted over wallpaper paste ndcllions Painting 3 06-22-2011 06:09 AM
