Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-04-2011, 03:29 PM   #1
Overlapping Tapping
When tapping end joints by tapered joints, or other areas where taping will overlap.
Do you overlap the tape or cut it so it doesn't over lap.
jburchill is offline   Reply With Quote
Old 08-04-2011, 04:59 PM   #2
Too Old
Overlapping Tapping
I have always ran tape from the butt joint into the factory joint, I do this first then tape the factory joints and leave the corners for last. Not saying it's the only way or the right way but it's the way I have done it for years.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Tapping CPVC supply lines for new bathroom - question NEW-B Plumbing 0 05-12-2011 10:20 AM
Overlapping wood siding Ronnie1a Building & Construction 3 02-05-2011 07:00 PM
overlapping standing seam tin woodboy Roofing 4 02-23-2009 04:27 PM
Tapping noise in wall after flushing upstairs toilets John VH Plumbing 2 01-21-2008 12:24 PM
Tapping a water line for fridge Statecowboy Plumbing 6 10-12-2006 12:45 PM
