In Over My Head.. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 01:45 PM   #1
Rewards Points: 640
in over my head..
well after doing another 6ft x 6ft bathroom drywalled I think its time for me to call in the pro's to drywall a 26x30 ft room... how long would you guys think it would take to finish a room like that? ceiling and walls with only 4 doors in it. probably take me 2 months at the rate I am going and messing up mudding just trying to figure out if I should hire that out or not..... not sure what to expect cost wise either... never hired a job out yet, always did things myself unless it was too dangerous for me...
BlueBSH is offline   Reply With Quote
Old 06-28-2011, 02:14 PM   #2
the Musigician
DangerMouse's Avatar
I drywalled all of the ceilings and walls in my whole house. I'd never done it before either... it does take a little time to get the hang of mudding.
But I would just keep going if I were you. What problems are you having with the mudding?
DM
Old 06-28-2011, 02:18 PM   #3
Rewards Points: 640
DM
butt joints are driving me nuts.... everything else its fine and on a ceiling I think I am gong to rip my hair out doing them since I can only get 8x4 drywall into my basement
been contemplating either hiring it all out and getting it done fast as possible, hanging the drywall myself then hiring out the taping and mudding... or going insane for a couple months
Old 06-28-2011, 02:28 PM   #4
the Musigician
What about taping the butt edges and texturing the whole ceiling? Or put up tin, or fake foam tin look?
Plenty of options.
DM
Old 06-28-2011, 02:32 PM   #5
Rewards Points: 640
Plenty of options.
DM
nah, I've already decided I want a flat white ceiling, have texture upstairs and don't really like it much.. texture right now would be my last resort
Old 06-28-2011, 03:46 PM   #6
the Musigician
Welp, practice with that big knife! Unless of course you can AFFORD to employ someone else to do it....
DM
Old 06-28-2011, 04:59 PM   #7
Old School
Willie T's Avatar
I've about decided to just quit telling people about butt boards. No one seems to listen.
Willie T
Old 06-28-2011, 05:51 PM   #8
the Musigician
hmmmmm, I can only find one thread where you even mentioned them....
DM
Old 06-28-2011, 06:29 PM   #9
Rewards Points: 640
quit telling them what? even following how it is supose to be done I always get a hump in the middle even feathering out to 24 inches on each side... somehow even light coats I still get them drives me nuts even had a pro show me and I follow what they did and still same result ugh
Old 06-28-2011, 07:36 PM   #10
When I did my house(and still am for the most parts)I made my own butt boards.Pretty sure I used 11"Wx50" L 1/2" mdf scrap I had.Cut up 2 1" wide thick scrap vinyl I had stapled the full length on each edge.Worked like a champ!!!!!!Don't really need them tho just tried it out.
Jasonlongor1 is offline   Reply With Quote
Old 06-28-2011, 08:03 PM   #11
Rewards Points: 640
huh? I think we are talking about two totally different things, I'm talking about butt joints on drywall
Old 06-28-2011, 08:05 PM   #12
Rewards Points: 640
maybe I just need to hire out the ceiling? its probably not good to have your hand in the air that much if you have poor circulation in your arms, would you think? I think I can handle the walls since there would be no butt joints there
Old 06-28-2011, 08:22 PM   #13
Ha ha no we are talking drywall butt joints.By using these it gives you a slight taper in the butt joint to help tape over!!If this is a problem for you these do help!!!You can buy them or make your own as I did.
Old 06-28-2011, 08:59 PM   #14
Rewards Points: 640
oooooooooo ok now I get what you said *lol* I was thinking you meant butt joints when you join two boards together with the V notches and glue... sorry!
Old 06-28-2011, 09:28 PM   #15
MikeKy55's Avatar
Rewards Points: 254
You can do it. I'm doing my basement now (1,100 sq feet) by myself. Yes, the butt joints are the worst part for sure, but not impossible. You have to learn that feathering them out 18 inches or so on either side pretty much makes them invisible unless you paint with a high gloss paint. Flat ceiling paint should make them hide very well. Personally the dreading doing them is much worse than actually doing them.
I read everything I could find on this site and ended up asking for clairification on a few points. This place is a gold mine of information and the professionals here are kind enough to help.
One thing I have learned is not to look at ALL you have to do at once. Choose one area and look only at it until your satisfied and them pick another. Before you know it you will have a lot done. I don't move to the next area until I'm satisfied the one I'm working on is ready for primer.
MikeKy55 is offline   Reply With Quote
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 09:00 AM
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-24-2010 11:31 PM
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 06:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 11:23 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
