Outside Corner -- Plaster Meeting Exposed Brick - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 04:03 PM   #1
Rewards Points: 1,062
outside corner -- plaster meeting exposed brick
I have an outside corner where plaster on one side meets exposed brick on the other. It all used to be plaster but I stripped off the side where it's now brick. The line is pretty straight cause I cut it with a 4.5" diamond blade but i would still like to make the corner fully plaster, i.e. cover the gray 3/4" thick old plaster with finishing to look like the plaster on the right side. IOW, I don't want the inner coat of plaster to be visible.
What I was thinking of doing is take a 2x4 and affix the 4 side along the brick side and the 2 side flush with plaster (hold it in place clamped to an adjacent window recess) and then tuckpoint the hole between the 2x4 and plaster to make a perfectly molded corner.
My question is: What is the best type of compound to do this with? I need something super light and strong so that it keeps adhered and doesn't crumble. I am afraid my plaster mix (2.5 masonry sand to 1 hydrolic plaster lime) might crumble and detach. Is drywall quickset mud a better option? Once I have molded the perfect corner, I plan to put a metal corner bead (using adhesive, not nails)
outside corner -- plaster meeting exposed brick-plaster_brick_corner_prcsd.jpg
trying to match interior plaster over brick ironnickwhite Drywall & Plaster 2 11-14-2012 08:38 PM
plaster meeting new rock j_marie Drywall & Plaster 3 07-22-2012 11:41 AM
Inside corner on small corner jburchill Drywall & Plaster 0 09-21-2011 11:08 PM
Two colors meeting in a corner jason29 Painting 2 05-01-2007 04:46 PM
I'm going to end up with a seam of greenboard meeting plaster, how should I finish? J187 Building & Construction 2 06-06-2006 08:53 AM
