Outside Corner Basic Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 04:11 PM   #1
Rewards Points: 1,062
Question
outside corner basic question
i am asking this question because my book is not specific about it one way of the other.
when setting an outside corner, should the screws that hold it in place be the same screws that hold the corner bead in place? i would think that would make sense to minimize the number of screws and maximize the fastening of the bead.
or should i first fasten the panels in the corner with one set of screws and then, once it is tight, set the bead with another set of screws. that way, the corner is tight before i set the bead BUT there would be more screws, which means more exposure to chip edges etc.
i hope the question comes across understandable.
thanks
Old 05-11-2012, 05:13 PM   #2
I would just fasten the drywall first make sure the screws are deep enough so they dont interrupt the corner bead installation, then get the ''847 Trim-tex'' glue and glue the corner bead on the corner. No need to use screws to hold it on, once you apply a few coats of mud on it it will never move.
fireman33 is offline   Reply With Quote
The Following 2 Users Say Thank You to fireman33 For This Useful Post:
amakarevic (05-11-2012), oh'mike (05-11-2012)
Old 05-11-2012, 06:07 PM   #3
DIY staff
Rewards Points: 7,174
I set metal corner bead with a small crown stapler---works for me--
No screws in the corner bead--use drywall nails--screws will pucker up the tin and make a mess--Mike--
Old 05-11-2012, 06:17 PM   #4
You think a regular stapler like this will work?
Old 05-11-2012, 06:55 PM   #5
DIY staff
Nope---1/4" small crown staples 1 1/4" long---Unless the job is huge--just buy a box of drywall nails--
Old 05-11-2012, 07:02 PM   #6
Question
so you don't agree with the adhesive recommendation above?
Old 05-11-2012, 07:20 PM   #7
DIY staff
I do agree--that stick on bead is good stuff---I only offered the methods of installing the tin corners in case you already purchased them---
Old 05-11-2012, 07:44 PM   #8
currently i'm doing the bathroom and using plastic beads
Old 05-11-2012, 11:19 PM   #9
Registered User
Rewards Points: 5,482
Always better to fasten to the drywall than the wood framing which moves with humidity/heating/cooling changes: http://bestdrywall.com/files/ReduceCallbacks.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
amakarevic (05-12-2012)
Corner bead question Aloha1 Drywall & Plaster 10 02-21-2012 09:38 PM
corner bead question hiding mud line petros151 Drywall & Plaster 9 02-18-2012 06:02 PM
basic question - single pole switch in a 3-way setup dbpass Electrical 10 09-07-2010 05:29 PM
Drywall corner question Anne Drywall & Plaster 2 11-13-2009 03:50 PM
Basic woodworking question... mako72 Carpentry 7 01-28-2008 07:17 AM
