#1 |
OSB strapping ok?
Was wondering if there's any reason why I shouldn't use OSB as drywall strapping (as opposed to spruce 1x3s). I have a bunch of 5/8" OSB offcuts that I'm planning to cut into strips and attach to wall studs.
I was thinking the only potential caveat to my plan would be to use this below the windows in case of any water infiltration, but I thought I'd put the question to the experts nonethelss .Thanks, Lobos |
#2 |
OSB strapping ok?
Lobos,
I wouldn't use osb for much of anything. Just my personal opinion. It swells and falls apart when it gets wet. Using it in place of solid sawn wood is not a good idea. It's not as strong. Get some 1 x 3's and be done with it. Do it once, not twice. Mike Hawkins
#3 |
Moderator
OSB strapping ok?
You also lose the drywall warranty: " 2.2.8.1 Wood framing members shall be of the proper grade
for the intended use and shall comply with American Softwood Lumber Standard, DOC Voluntary Product Standard PS 20, or Softwood Lumber, CAN/CSA-O141. 4.1.3 Where gypsum panel products are nailed to wood cross furring on ceilings, those furring members shall be not less than 1 1/2 in. x 1 1/2 in. (38 mm x 38 mm) actual size and shall be spaced as specified in Tables 1, 4, and 5. Where screw application is used, wood furring members shall be not less than 3/4 in. x 1 1/2 in. (19 mm x 38 mm) actual size." High-lights mine, from: Also has floating corners, prime before and after texturing, etc. http://www.gypsum.org/pdf/GA-216-07.pdf Tips: http://bestdrywall.com/files/ReduceCallbacks.pdf http://www.finehomebuilding.com/PDF/Free/021174058.pdf Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 | |
Framing Contractor
OSB strapping ok?Quote:
Joe Carola |
#5 | |
OSB strapping ok?
Thanks for the quick feedback everyone... Gary, thanks for the references.
That said, I was under the impression that it is simply best practice to apply strapping to exterior wall studs in advance of drywall installation. Your question leads me to believe that this isn't the case. Thanks, Jeremy |
#6 | |
Framing Contractor
Strapping walls isn't best practice at all, in fact that is something that I've never seen or heard of done. Strapping isn't necessary at all. Some places do it by choice. It is not code anywhere. The only time I have ever put put fiurring/strapping on is on an existing ceiling that is not straight. There is no need to do it at all on new work.
Joe Carola |
#7 | |
| Display Modes | |
| Simple question on strapping | satz | Building & Construction | 8 | 11-27-2009 10:21 PM |
| Floor bounce joist sistering | joehomeowner | Building & Construction | 24 | 05-10-2009 02:50 PM |
| Strapping a ceiling | duburban | Building & Construction | 2 | 04-13-2008 02:34 AM |
| straping for basement ceiling | handyflyer | Remodeling | 3 | 02-26-2007 10:46 PM |
| Ok to run wiring between strapping in the ceiling? | peeks | Electrical | 5 | 08-29-2005 01:12 AM |
