Order Of Coating Drywall. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 08:39 AM   #1
langless28's Avatar
Rewards Points: 152
Order of coating drywall.
Have all my tape done, getting ready to use my 10" knife for the first coat. I'm not a professional so I plan on doing the angles one side at a time, but should I do the recessed joints or the angles first? Or can they be done at the same time?
langless28 is offline   Reply With Quote
Old 12-08-2012, 10:18 AM   #2
Have the tape done? Using mesh tape of do you have the first coat of paper in mud?
I usually use paper so at this point it would actually be a second coat. I like to do one side of the corners, ie lefts and tops, and then depending on the size and type of mud either do the other side after the first side is done. After that move to the flats. Reason I don't like to do flats first is when you do the corners it's much more difficult in my opinion to get the corner looking good.
Don't use mesh in corners but if I did I'd want to do it similar to paper where the first coat of mud went on both sides and then repeat additional coats as above.
mbryan is offline   Reply With Quote
Old 12-08-2012, 10:59 AM   #3
langless28's Avatar
Rewards Points: 152
Yes I used paper and mud. Technically i would be on second coat. A lot of website I have looked at don't count tape and mud as first so that why i said first coat. Just logistics thought, call it whatever you like
Old 12-08-2012, 01:32 PM   #4
Rewards Points: 454
It goes tape,fill,finish.I usually do the butts first because it will take the most mud and you should put mud 12" on both sides of the joint.
scottktmrider is offline   Reply With Quote
Old 12-08-2012, 01:59 PM   #5
langless28's Avatar
Rewards Points: 152
I have a small 100sqft kitchen and used 12' sheets so no butt joints
But I will do angles then the recessed joints I presume.
Old 12-08-2012, 05:26 PM   #6
retired union carpenter
Send a message via Yahoo to coupe
I always use paper tape, tape joints first and second coat all flats, joints and butts. this fills the tapered joints up a bit except for maybe a half inch from angle. then the paper tape and mud doing angles will blend into the tapered joints nicely, I use a 12" trowel on tapered joints each side and 16" on butt joints each side giving 24" and 36" coats
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-08-2012, 06:05 PM   #7
Rewards Points: 6,034
To save you some time and work the final coat is the only one where you need to do your angles 1 side at a time.
Old 12-08-2012, 08:00 PM   #8
automated tool pro
Rewards Points: 152
it sounds like you're doing fine. I would suggest using the right sized knife for running your angles though.....make sure it's a 4" knife. It will make your life a lot easier.
drywallfinisher is offline   Reply With Quote
Old 12-08-2012, 10:00 PM   #9
Rewards Points: 4,796
Regardless of what the pros use, I recommend the corner knife. It just makes your life much easier.
1st coat: apply about 3-4" mud with 6" knife to each side of corner, fold tape and apply, coat tape again with 6" knife to embed.
2nd coat: Sand any ridges in the corner left by first pass. Apply mud with 6" knife to both sides of corner, and rip it down with the corner knife. So easy.
3rd coat: You can probably avoid sanding the 2nd coat. Avoid the actual corner now, because it's about perfect. You now have about 3-4" of mud on each side of the corner. Apply the 3rd coat to the outer edge of this strip again with a 6" knife, another 3" of mud, avoiding the actual corner, finishing with about 5" of mud on each side of the corner.
The corner knife is quite flexible and will fit corners that are not exactly 90 degrees. The finished result will not be quite as crisp as a perfect corner by a top pro (because up close, the corner knife is just slightly rounded at the corner), but it's so uniform and consistent and fast, you'll be happy.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
ToolSeeker (12-09-2012)
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 04:17 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
