Orange Peel Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 12:05 PM   #1
Orange peel ceiling
Hi building a new home and we want to do orange peel ceiling and want advise on how to do this ourselves. Hope someone can help us
Grandmacher is offline   Reply With Quote
Old 02-27-2011, 01:32 PM   #2
Registered User
Rewards Points: 526
Welcome to the forum!
I'll move you to "drywall" where they will explain about spraying water-based texture.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Grandmacher (02-27-2011)
Old 02-27-2011, 04:46 PM   #3
Old School
Willie T's Avatar
Before you get too involved with this, may I ask why you want to do Orange Peel as opposed to, say... a smooth finish or perhaps 'Knockdown'?
Willie T
Old 02-27-2011, 04:56 PM   #4
Orange Peel
Because we owned a home that had orange peel ceilings or at least thats what we were told. From researching today I see knock down sounds like what our orange peel was. Someone said you spray ceiling then use a 12" putty knife to smooth it down.
Old 02-27-2011, 05:03 PM   #5
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
I won't even ask why they want to do orange peel so just ignore that comment above.
I have sprayed many homes with all orangepeel. in fact i have done orangepeel ceilings and knockdown walls.
If that is what they want then let them get it. My expert advice is to contract a professional that uses a spray machine that is mounted on a trailer that can only be pulled by a vehicle. Yes you can do it yourself, but it won't look good at all (although you will think it looks like a million bucks, i would think it looks like an inconsistant mess).
However shall you choose to ignore my warning here are the steps.
rent a decent sized portable sprayer that has a hopper and a pump built in. Preferably a 15 gallon bucket on it.
You will need a mixing drill and a paddle for the next step. Get joint compound by the bucket. mix it with water until the consitency runs off the mixing paddle and you can kind of see threw the mixture.
dump that into the hopper. use the spray gun and a tip that look like it is just a small rectangular slit. you will want to experiment with different settings such as low mud output and high air output.
then you spray it on, and clean it off the walls. THERE WILL BE TONS OF OVERSPRAY ON THE WALLS THAT WILL NEED CLEANING OFF UNLESS YOU COVER THEM.
This should cover it.
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 02-27-2011, 05:06 PM   #6
stoner529's Avatar
Rewards Points: 154
This is knockdown. we use our spray rig to do this as it makes a nice even pattern. I have some pictures on my websites below.
We use large plastic knives on polls. otherwise you will be doing this all day with a putty knife.
Take my above warning from the orange peel post and double it for knockdown. I will not even attempt to spray knockdown from my 15 gallon portable.
Old 02-27-2011, 05:51 PM   #7
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
Here's our medium Knokdown texture:
Here's our Orange peel texture:
Sir MixAlot is offline   Reply With Quote
Old 02-27-2011, 05:55 PM   #8
Orange Peel
Sir Mixalot the knockdown pic looks like what we had. The pic of orange peel is hard to really see what looks like.
Old 02-27-2011, 05:58 PM   #9
Registered User
Rewards Points: 526
That is great you want to DIY! A whole house would be a lot of work... If you could break it into smaller portions that are more manageable......
Try watching some of the many Videos on "Knock-down" on the web for more understanding of the process. This will get you started on the basics, click on the titles with “Preview” in the title; http://www.google.com/search?tbm=bks&tbo=1&q=spray+texture&btnG=Search+B ooks
Pics; http://www.drywallschool.com/textures.htm
Gary
Old 02-27-2011, 06:00 PM   #10
Orange Peel
Not doing whole house. Just doing bedrooms as kitchen/livingroom done in pine.
Old 02-27-2011, 06:02 PM   #11
stoner529's Avatar
Rewards Points: 154
That is a small splatter orange peel.
Old 02-27-2011, 07:06 PM   #12
Rewards Points: 918
It's hard to get a good pic of Orange peel texture.
Here's a different one of Orange Peel.
Old 02-27-2011, 08:03 PM   #13
Orange Peel
Thanks for pics and think its the knokdown texture we are looking for.
orange peel prevention? Millertyme Painting 4 01-18-2011 04:43 AM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 03:47 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Same Ceiling: orange peel and knockdown sir_rob Painting 17 10-01-2007 04:28 PM
Knockdown ceiling : My walls are orange peel.. Arkanoid Remodeling 4 08-07-2007 12:23 PM
