Old Tape/mud/Paint - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 04:18 AM   #1
Rewards Points: 150
Old Tape/mud/Paint
before hand texturing the breakfast room, i have opened up all bad seams for taping and discovered an old taping job that looks to have been done twice. this patch job was probably from a water leak before the new roof. so what caused it should not happen again.
Old Tape/mud/Paint-dscf3057.jpg
as seen in the photo, most of the loose tape/mud/paint has been removed.
can i tape/mud over this so it is flat in prep for a hand texture?
Note: this is the same attic with little to no access and there happens to be some sort of large metal box over part of this patch job.
rosco is offline   Reply With Quote
Old 07-03-2010, 05:27 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 320
I can see no reason not to.
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
rosco (07-03-2010)
Old 07-03-2010, 01:40 PM   #3
Rewards Points: 150
the area is about 3'x3' and the patch job kinda sticks out about 5mm.
i'm afraid the old patch job may be loosened by the moisture in the mud and further separate.
we'll try tape/mudding and see what happens in a year.
Old 07-03-2010, 04:18 PM   #4
Rewards Points: 150
empty void behind tape or hunk of mud on top of tape?
these pic's are that good but it kinda shows my present task. Old Tape/mud/Paint-dscf3058.jpgOld Tape/mud/Paint-dscf3059.jpg
the void i am to fill in is at least 0.5 cm.
  • do i fill it in with joint compound and let it dry before taping?
  • or just tape the large gashes and "mud" over this? it seems this will either leave a void behind the tape or a thick layer of mud on top of the tape.
    • if this is the technique, should the tape be drawn tight over the void so there is a gap behind the tape?
    • or is the tape to be flattened against all surfaces.
Old 07-03-2010, 06:30 PM   #5
DIY staff
Rewards Points: 7,174
Fill all gaps with Durabond (bag mix) before taping.
rosco (07-03-2010)
