Old Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-18-2014, 08:39 AM   #1
Rewards Points: 2
old plaster
bathroom remodel. walls are plaster down to 4 ft from floor. some type of paperboard from there down. In between there is a strip of wood. what was it for? to support the plaster? would like to take it down to the studsold plaster-1.jpg
denny621 is offline   Reply With Quote
Old 12-18-2014, 09:04 AM   #2
Rewards Points: 13,446
May have been a backer to attach a chair rail, towel rack, wall mounted sink to, it's not needed to hold up the plaster.
Outside wall?
A house that old was built with rough lumber, before sheet rocking take the time to pull a string across the wall to check to see if they need shimming or sistering to make the wall flat.
Old 12-18-2014, 09:10 AM   #3
joed's Avatar
Rewards Points: 12,356
It's not there to hold up the plaster. It was probably just installed to demark the edge of the plaster.
Old 12-18-2014, 11:29 AM   #4
Rewards Points: 5,974
My first thought is since the plaster stopped up 4' from the floor is at one time there was a leak. They removed the plaster up 4' so a sheet of drywall would fit horizontally around the room. The board was installed to screw or nail to.
outside corner -- plaster meeting exposed brick amakarevic Drywall & Plaster 0 12-29-2012 03:03 PM
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 08:28 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
