Old Outlet Boxes- Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 08:58 AM   #1
old outlet boxes- drywall
I had to move some old outlets for my new kitchen layout- I have 2 old outlet boxes still in the wall (no wires)- They are in a location where my new backsplash will eventually go. Do I leave the old boxes there- put a plastic cover over and spakle over it?- or try to get the boxes out and use some type of drywall patch?
skinut2234 is offline   Reply With Quote
Old 10-25-2012, 09:03 AM   #2
Rewards Points: 13,274
I would remove the box and patch the hole. Reason being there's a hole that the wires were run to it in the top or bottom plate that will leak air.
Old 10-25-2012, 09:42 AM   #3
Rewards Points: 5,974
The big box stores carry a drywall patch that is a thin sheet of aluminum with a thin fiberglass mesh on top they come in different sizes like 4"x4" 6"x6" and 8"x8" so you could leave the boxes in. These patches are sticky on the back so you don't have to use screws. They are very DIY friendly, but cover them with joint compound 2 coats, sanding between coats. Just be careful you don"t sand clear thru the compound. Good Luck let us know how it turns out.
Old 10-25-2012, 10:36 AM   #4
Thanks- yes- I've used the patches before (they work well)- Was just wondering if it's standrd practice to take the old boxes out of the wall- I would think that is best to make for a cleaner install overall
Old 10-25-2012, 10:43 AM   #5
The boxes should be set back just a little or if they are even, as long as they don't hold the patch out away from the wall it won't effect the install at all. But by all means if you are more comfortable with it take them out.
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 08:07 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
drywall repair next to an outlet - advice needed... myke232 Drywall & Plaster 2 08-19-2009 01:25 PM
Blue electrical boxes are to far in the drywall smblank3 Drywall & Plaster 3 05-19-2009 12:37 AM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 01:05 PM
