-   -   old outlet boxes- drywall (http://www.diychatroom.com/f101/old-outlet-boxes-drywall-161107/)
skinut2234 10-25-2012 07:58 AM
I had to move some old outlets for my new kitchen layout- I have 2 old outlet boxes still in the wall (no wires)- They are in a location where my new backsplash will eventually go. Do I leave the old boxes there- put a plastic cover over and spakle over it?- or try to get the boxes out and use some type of drywall patch?
joecaption 10-25-2012 08:03 AM
I would remove the box and patch the hole. Reason being there's a hole that the wires were run to it in the top or bottom plate that will leak air.
ToolSeeker 10-25-2012 08:42 AM
The big box stores carry a drywall patch that is a thin sheet of aluminum with a thin fiberglass mesh on top they come in different sizes like 4"x4" 6"x6" and 8"x8" so you could leave the boxes in. These patches are sticky on the back so you don't have to use screws. They are very DIY friendly, but cover them with joint compound 2 coats, sanding between coats. Just be careful you don"t sand clear thru the compound. Good Luck let us know how it turns out.
skinut2234 10-25-2012 09:36 AM
Thanks- yes- I've used the patches before (they work well)- Was just wondering if it's standrd practice to take the old boxes out of the wall- I would think that is best to make for a cleaner install overall
ToolSeeker 10-25-2012 09:43 AM
The boxes should be set back just a little or if they are even, as long as they don't hold the patch out away from the wall it won't effect the install at all. But by all means if you are more comfortable with it take them out.
