Old - New Drywall Match - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 04:45 PM   #1
The old Drywall hangs a bit lower than the new drywall henchforth they are not level with each other. I have added a 2 x4 on top of the old drywall and braced it with a smaller 2 x 4 and nailed it in to the joist to give it some stability. I then screwed in some drywall screws to raise the old drywall hopling to level it with the new drywall. This helped a bit however still not 100 per-cent. Any help would be most appreciated.
blue collar is offline   Reply With Quote
Old 02-02-2012, 04:49 PM   #2
Rewards Points: 13,296
Is this in a ceiling?
Without being there to see it my first guess would be someone installed the wrong thickness of drywall.
There's 1/2 and 5/8 drywall. Using the wrong one would explain the step.
I like to use 5/8 because there no sagging between the rafters.
Old 02-02-2012, 05:17 PM   #3
Without been there to see it my first guess would be someone installed the wrong thickness of drywall.
Yes it is the ceiling. The old drywall is 1/2 , the new is 1/2.
Old 02-02-2012, 05:23 PM   #4
Was the seams located in the middle of the rafters? Or is the ceiling just unlevel?
How about a picture?
Old 02-02-2012, 05:32 PM   #5
Middle of the rafters is correct. Picture to follow later.
Old 02-02-2012, 05:39 PM   #6
What's the span between the rafters? How wide are they?
Old 02-02-2012, 07:07 PM   #7
Problem area . Spacing is 18 1/2 Inch. The problem area is approx. 4 - 5 inches and is approx. 1/16 Inch variance over this distance. Im thinking I might be able to blend it in with the mud. Of course more sanding than I would like.
How to paint drywall after patching? kennykenny Painting 10 01-27-2012 09:55 PM
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
