Old Inside Corner Tape Failing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 11:56 AM   #1
Rewards Points: 262
Old inside corner tape failing
In my bathroom renovation I managed to save the top half (4ft) from demolition or so I thought. On closer inspectio, it appears that the old paint has cracked and the tape has split at the cracks. I probably already know the answer to this. Do I need to sand off all this old corner tape and start over with new tape? Or can I get away with mudding or painting over this area?
Jim F is offline   Reply With Quote
Old 06-09-2010, 12:05 PM   #2
Old School
Willie T's Avatar
What has likely happened is that when the original D/W was hung, they fastened both sides of the corner up close. This seems proper, at first, but it is a poor practice because when walls move a little in relationship to each other, (and they will) the solidly fastened down inside corners have no flex and the tape usually cracks... along with the paint on top of the tape.
You can either sand the old tape, or tape over it... really doesn't matter... it will keep on happening as long as the walls find a reason to move some.
Willie T
Old 06-09-2010, 02:06 PM   #3
Handyman
Rewards Points: 512
I am seeing more and more of this in newer homes. I've seen a couple where the paint starts riplling at the corners and lots of cracks. When I peel the paint back I can tell that there is only one layer of mud laid (the first layer) and that's it. No wonder they have houses popping up overnight
canadaclub is offline   Reply With Quote
Old 06-12-2010, 11:29 AM   #4
Drywall contractor
Rewards Points: 1,070
It would be best to tear out the old tape and retape the corners....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-12-2010, 02:57 PM   #5
Handyman
Rewards Points: 512
absolutely
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-22-2010 12:13 AM
Aged Painting Tape Needs to Come Off user1007 Painting 2 03-04-2010 06:16 PM
Left or right hand crown inside corner? Klawman Carpentry 9 01-08-2010 04:19 PM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 04:52 AM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
