Old Drywall, Bad Joints - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 09:00 PM   #1
Rewards Points: 502
old drywall, bad joints
redoing a room. It has drywall, but it was never taped, so all the joints are still visable, even through a half dozen layers of paint. It also has some nails popping up.
what do you guy suggest?
I see a few options:
1. tape and putty
2. sand a shallow grove, then tape and putty.
3. put up another layer and do it right; with screws and taped joints.
I don't see the need to tear down the old stuff first. if nothing else, its more insulation, just try to stagger the joints some.
4. live with it like the they did for the last 90 years or so.
forresth is offline   Reply With Quote
Old 09-20-2010, 02:55 PM   #2
It depends on what you want to do, me I would tape and finish joints, maybe sand the areas to be taped. I have put 1/4 drywall over textured walls that homeowner wanted smooth, 1/2 drywall over popcorn and stippled ceilings rather than tearing out old drywall. The easiest solution would be to tape and finish existing joints.
newfie49 is offline   Reply With Quote
Old 09-20-2010, 04:34 PM   #3
Drywall contractor
Rewards Points: 1,070
I'd tape and finish what's there also if the rest of the walls aren't too rough. Problem is, if you get the joints nice and slick and the rest of the walls are rough due to lots of paint, your smooth joints will make the rest look bad or they will stand out. If you can get the same "texture" on the joints when you paint (same "roughness from the roller) you'll be ok. If you add another layer, you'll have issues with the door and/or window jamb thickness to deal with, but that's not a "deal-breaker". It's kind of a matter of how nice of a finish you want. New rock will give you the best job.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 09:09 PM
Drywall butt joints question kupalino Drywall & Plaster 6 04-08-2010 12:46 PM
Tape drywall joints before painting? mcraenz Drywall & Plaster 7 11-19-2009 06:28 PM
Drywall stagger joints? J187 Drywall & Plaster 5 04-15-2009 08:55 PM
Butt Joints at new drywall and existing corner round VistaV Building & Construction 1 02-03-2008 09:36 PM
