Old Ceiling Drywall In Wrong Direction - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 09:50 AM   #16
The trusses are definitely 24 inch, and the roof is not sagging at all.
I do think that the drywall is 1/2 inch though.
I put a level and tape measure on the ceiling, and each sheet has 3/8 inch difference between the lowest point and the edge of the piece of the drywall. There are definitely nails holding the center of the sheet, but they have come down 1/4 to 1/3 inch with the drywall.
jdbowman is offline   Reply With Quote
Old 10-23-2013, 10:02 AM   #17
There are nails in the center of each piece in the center truss, and they are 1/4 to 1/3 inch pulled out according to the amount of sag at that point.
Old 10-23-2013, 06:37 PM   #18
DIY staff
Rewards Points: 7,174
Lift it back up--hopefully no insulation has slipped between the drywall and the framing--then add more screws---
That is very loose---I was removing a loose ceiling in a kitchen---one good pull and the entire 10 x14 ceiling came down in one fell swoop----Bang, Big bang!!!
Old 10-23-2013, 07:14 PM   #19
Rewards Points: 5,974
1/2" is recommended for 16" centers and 5/8" for 24" centers. Over time this has probably caused the sag. If you have access from above you may need to add some cross bracing between the trusses just to have something to screw to. Just don't be too surprised if you end up having to replace it.
Old 10-24-2013, 09:48 AM   #20
Thanks to everyone. Last "?" Does replacing it necessarily mean ripping the old one down or can I place the furring strips every 4ft where the drywall is still tight and install a new ceiling in the correct direction.
Old 10-24-2013, 09:07 PM   #21
With it sagging this bad remove and replace.
Old 10-25-2013, 06:02 AM   #22
DIY staff
It's loose and bagged and sagged----best option is to remove it.
Cover the floor with several layers of heavy plastic---cut the corners at the wall/cieling using a utility knife----then bash a hole with a hammer---and pull with a rake or hoe----remember--this might all fall at one time---so be careful-----
ToolSeeker (10-25-2013)
Tags
carpentry , drywall , painting
Drywall Corner and Ceiling Skim Coat Rbchound Drywall & Plaster 6 04-29-2010 10:59 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 09:11 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
