Is It Okay To Let Drywall Rest On A Wall Cabinet? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-29-2013, 10:44 AM   #1
Question
Is it okay to let drywall rest on a wall cabinet?
I had a section of ceiling damaged by water. The section projects out further than the rest of the ceiling. It is roughly a 6'x8' section that protrudes vertically from the ceiling by about a foot. This sections butts up against a wall which has cabinets attached to it.
I was able to remove the ceiling drywall (with some difficulty) without removing the cabinets. There is now roughly a 1/2" gap between the top of the cabinets and the ceiling joists.
My question is this; would it be okay to let the last couple of feet of drywall just rest on top of the cabinet? I am unable to reach the joist that butts up against the wall as well as a couple of feet of the joists that run perpendicular to the back wall joist (i.e. there is a roughly U shape section I wonít be able to screw the new sheet of drywall to).
I would hate to have to take the cabinets down. They appear to be old and I think it was assembled on the wall. I donít think I would be able to remove it without damaging it and I would prefer to keep it.
Thank you in advance for any advice.
oracle8202 is offline   Reply With Quote
Old 11-29-2013, 11:50 AM   #2
Rewards Points: 5,974
Yes it would be OK
The Following User Says Thank You to ToolSeeker For This Useful Post:
oh'mike (11-29-2013)
Tags
cabinet , cabinets , drywall , wall , water damage
Question: BNC cables through attic (studs to wall, or ceiling drywall?) eatmyturf Electrical 4 04-05-2013 11:25 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 11:47 PM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-03-2011 12:09 AM
