Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-30-2009, 01:23 PM   #1
Is It Okay To Hang A Sheet Of Drywall On An Angle?
Hey, can anyone answer this question? I have a stairwell that had a railing from the landing to the top and now we are removing the railing and extending the wall up to 40" with a railing protruding from it. We stripped the drywall cap off and now we're framing the extension. I'd like to hang the drywall on the angle since it's most of 1.5 sheets. Is that angle going to tape out well? or should I be tearing the drywall back to horizontal and have a series of joints with the drywall cut off on an angle at the top?
moondriver is offline   Reply With Quote
Old 04-30-2009, 01:51 PM   #2
Whatamess
It should be OK but you may want to post a picture to make sure we understand the question.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 04-30-2009, 01:54 PM   #3
Oldguy
Rehabber's Avatar
As long as the sheets join on a stud, use the method that will allow the fewest joints
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 04-30-2009, 01:57 PM   #4
Tool Geek
PaliBob's Avatar
Why Not? Aren't ceilings at an angle?
If your question is really about the aesthetics on how it would look then post a couple of pics?
& Stay Safe
.....Bob Lavery
Old 04-30-2009, 02:29 PM   #5
Can you tell me how to post a drawing or a photo?
Old 04-30-2009, 02:42 PM   #6
OPen a photobucket account, free at photobucket.com
Upload you picture there by clicking "upload pictures and files"
Once you image is uploaded there, run you cursor over the thumbnail image, a box below the image will drop down. Copy the "Direct Link"
When replying here, click on the little yellow graphic above that looks like a sun over a mountain, paste code. Done
bdobs is offline   Reply With Quote
Old 04-30-2009, 04:14 PM   #7
Here's a photo. I am going to frame above the drywall and continue it. Just wondered if I could run the drywall on an angle, if the joint would show.
Old 04-30-2009, 11:56 PM   #8
Should not be a problem.
Mop in Hand is offline   Reply With Quote
Old 05-01-2009, 12:03 AM   #9
Whether the joint shows or not will be dependent on your workmanship not the angle.
hayewe farm is offline   Reply With Quote
Old 05-01-2009, 01:02 AM   #10
Okay, that does it. I'm hangin' it on the slope!
I spoke to a drywaller buddy of mine and he agreed with you guys, that it's not going to make any difference, and it's just going to be another taping job.
So I'm going to let HIM do it!
Thanks a lot for all your replies.
Old 05-01-2009, 09:46 AM   #11
(the original)
How many times have I heard that? "No problem, the finishers'll get it..."
ratherbefishin' is offline   Reply With Quote
Old 05-01-2009, 01:12 PM   #12
Well, it was going to have a nice open railing with newel posts, etc. But the stairwell is already a gaping hole. So We decided to close it up a bit with the walls and a simple handrail. I want this puppy sold ASAP.
Old 05-01-2009, 04:22 PM   #13
Drywall contractor
If your buddy's any good, it won't be a problem. Of course every finisher I've ever hired was "the best", at least in his own mind....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Whats the longest sheet of drywall you have gotten thru egress window? bkeech Drywall & Plaster 12 02-05-2010 11:32 AM
What is the best way hang drywall (fasteners) tripower Drywall & Plaster 18 10-14-2008 06:25 PM
Hang the top piece of drywall first daxinarian Drywall & Plaster 14 07-23-2008 08:46 AM
Best way to hang drywall? 737Pilot Drywall & Plaster 15 07-20-2008 09:06 AM
off angle drywall hanging/finishing? ponch37300 Drywall & Plaster 2 07-14-2008 07:13 AM
