Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-02-2011, 11:01 PM   #1
Is it OK to screw into plaster.
I have a very old traditional style fireplace shaped out of plaster. I've remodeled the rest of the house for a more modern style, so I want the fireplace to match. I thinking something with clean straight lines, so my idea was simply to wrap the existing fireplace with drywall to cover the detailing that made the fireplace look so traditional, and mud it to give it it's straight lines. However, i'm not sure if screwing drywall into plaster is a good idea. Any ideas?
acerunner is offline   Reply With Quote
Old 06-03-2011, 06:40 AM   #2
Super Moderator
A question or two----What kind of plaster?--Wood lath with plaster or plaster over gypsum board?
If possible use drywall adhesive and a minimum of screws----often the screws will pop a chunk of plaster loose--causing a hump under the new drywall.--Mike---
Old 06-03-2011, 12:09 PM   #3
I remember seeing all white plaster from the backside when the walls were open. Unfortunately the walls are closed up now and I can't get a closer look. I don't think there is wood lathe, but I didn't see gypsum board either. It looked more like a hollow plaster shell, which doesn't quite make sense now that I mention it. so I must have missed something.
Old 06-03-2011, 07:15 PM   #4
Super Moderator
Plaster over gypsum is much less likely to chunk out with screws---Wood lath can be a big problem--
Use adhesive and only enough screws to keep the new Drywall in place as the glue sets.--Mike---
Old 06-03-2011, 10:03 PM   #5
take an awl and try finding the studs. we do it quite a bit but you do need to be careful not to get a broken chunk of plaster pinched between the rock . screws dont seem to grab lath very well it usually splits, hit the studs .
oldrivers is offline   Reply With Quote
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 10:12 PM
door hinge into a plaster wall? dbpass Remodeling 1 05-04-2011 12:49 AM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
